Results 1 to 22 of 22
    Apr 2012
    Iraq
    35
    623
    what are best method to cool reversing valve when install it
    hi
    i saw some people cool it using muds
    some other use wet rig
    and other using material they called it heating gel
    so what is the best method
    Aug 2007
    Sydney
    52
    1,083
    23
    Re: what are best method to cool reversing valve when install it
    Hi kefah
    I have used the heat gel and had no failures from overheating. Also it allows enough time to heat the pipe well enough to seal with welding. I had used wet rags in the past but also had leaks which had to be re welded.
    Apr 2012
    Iraq
    35
    623
    Quote Originally Posted by Tesla View Post
    Hi kefah
    thank you man
    can you explain more about heating gel material
    because i didnt find it in iraq
    11,025
    Somerset
    69
    4,698
    Interesting post, thanks Guys.
    I did not even know this stuff existed.
    One question though, as it evaporates. What's its shelf life like?
    Aug 2007
    Sydney
    52
    1,083
    23
    Not sure Grizzly but I had some in the back of the ute more than two years old. I wouldn't consider doing a four way valve without it.
    Apr 2007
    36
    371
    23
    Cool gel stuff looks quite good, i'll have a look about getting something and giving it a go.
    In the past some old rags that are soaked with water, wrapped tightly around the valve has done the trick.
    No problems yet...
    11,025
    Haven't used mine in a while but still workable. got it from Climate Center.
    Oct 2007
    manchester
    5,639
    45
    pyrokool is ok but the kool gel is better- last 4 way i did i had it submerged in a bucket and brazed the pipework onto it and then brazed onto the system with at least 12 inch of pipe on the tails so no dramas
    did a carrier eurotop 4 way 1 3/8 stubbs with wet rags and used 6ltr spray doc full of ice and water and had a chimp keep the rag cold!-again no dramas
    3,856
    Apr 2012
    Iraq
    35
    623
    thanx all for help
    i want to know what is thhat cooling gel
    what is content
    Oct 2007
    manchester
    5,639
    45
    http://www.laco.com/productDetail15.aspx
    data sheet doesnt state whats in it
    Apr 2007
    36
    371
    23
    Quote Originally Posted by kefah View Post
    thanx all for help
    what is content
    What the content is...is irrelevant. If it's not readily available i would stick with the basic field tested methods. Wet rag etc, or do as Install Monkey says and sumbmerge the valve in water, however DONT GET WATER IN THE VALVE.... you should know why not.
    Oct 2007
    manchester
    5,639
    45
    Apr 2007
    36
    371
    23
    Quote Originally Posted by install monkey View Post
    True pro at work....except the lumpy braze........
    Deserve Rep points for this!
    Oct 2007
    manchester
    5,639
    45
    been in for 3 month- note how the sticker on the body isnt scorched- also glo stick drops in the water, 2 others had allegedly repaired leaks on the system- small tubes had rubbed together so opted for the replacement option- and the quality of the braze is irrelevant as long as it doesnt leak as you only get a change to seal it before u refit it to the system
    Quote Originally Posted by jdunc2301 View Post
    Apr 2007
    36
    371
    23
    You know im only teasing IM...its common knowledge that i cant braze for ****!
    im still waiting to be accepted as a friend on FB...cannot wait!!
    Apr 2012
    Iraq
    35
    623
    thank guys
    i have more question
    after i install the RV
    and before charging the system
    how i can check if the RV working properly or not
  19. #19
    11,025
    thank guys
    You can't really because the RV needs systems operating pressures to move the valve shuttle inside.
  20. #20
    3,856
    Magnet trick to show rv is working (only works when system running with refrigerant in)
    http://www.youtube.com/watch?v=tsJLuTrezwo
  21. #21
    Apr 2012
    Iraq
    35
    623
    thank u guys
    you really helped me
    i appreciate that
  22. #22
    Apr 2012
    Iraq
    35
    623
    thank you all
    please close the thread
