Thread: Daikin FTXS50j
    Feb 2013
    Croatia
    73
    1
    Question Daikin FTXS50j
    Hello from Croatia
    Is the Daikin FTXS50J made by Gree Electric? Because I read that Gree makes the Daikin air con and I am wondering does it makes all models of Daikin or just small ones.
    Aug 2013
    Country
    5
    Re: Daikin FTXS50j
    They make only the cheap ones as far as i know. Here check this : http://tempex.bg/en/articles.php?pag...d=Daikin&inv=1
    Jan 2009
    Canary Islands
    74
    144
    Re: Daikin FTXS50j
    Gree make all the Daikin models in China. They have a dedicated line within their plant specifically for Daikin. European Daikin units are assembled in - I think - Czech Rebublic.
    Personally I like the Gree models that are available here in the Canary Islands. Installed loads and not had one problem. And - for example when you remove the carcase - its the whole carcase, not just the front cover. Makes installation - especially when the connections are behind the unit - a whole lot easier. The only others that I know I can do this with is Daikin and some Fujitsu/General multi interior units.
    Graham
    en boca cerrada no entran moscas
    May 2006
    Sussex
    362
    21
    Re: Daikin FTXS50j
    Errr, so Gree are quite cheap, and Daikin are enormously expensive.
    Surely Daikin are not ripping us off with their sky-high prices, eh?
