Thread: Daikin FTXS50j
22-02-2013, 07:16 PM #1
Daikin FTXS50j
Hello from Croatia
Is the Daikin FTXS50J made by Gree Electric? Because I read that Gree makes the Daikin air con and I am wondering does it makes all models of Daikin or just small ones.
22-08-2013, 12:55 PM #2
Re: Daikin FTXS50j
They make only the cheap ones as far as i know. Here check this : http://tempex.bg/en/articles.php?pag...d=Daikin&inv=1
29-08-2013, 11:29 PM #3
Re: Daikin FTXS50j
Gree make all the Daikin models in China. They have a dedicated line within their plant specifically for Daikin. European Daikin units are assembled in - I think - Czech Rebublic.
Personally I like the Gree models that are available here in the Canary Islands. Installed loads and not had one problem. And - for example when you remove the carcase - its the whole carcase, not just the front cover. Makes installation - especially when the connections are behind the unit - a whole lot easier. The only others that I know I can do this with is Daikin and some Fujitsu/General multi interior units.
Grahamen boca cerrada no entran moscas
31-08-2013, 11:33 AM #4
Re: Daikin FTXS50j
Errr, so Gree are quite cheap, and Daikin are enormously expensive.
Surely Daikin are not ripping us off with their sky-high prices, eh?
