    Jan 2003
    East Anglia
    1,160
    Computer Crash !!!!!!
    Hi Guys,
    My lovely ME PC has gone into meltdown again.
    I seem to have got it up and running again although i had to delete Norton Internet Security, or so i thought but the system doesn't seem to have deleted it all.
    When i boot up, i appears to be looking for file that dont exisist which i assume have been deleted but how do i stop it looking for them. I cannot reinstall at the moment as i get an error message saying that not all components of NIS have been removed, please remove and reload.
    The windows on boot up are
    Symnatec User Series
    A Neccessary file could not be loaded NAVprod
    " " " " " " " NISprod
    A Necessary component for this function is missing or damaged C:\program files\nortoninternetsecurity\nortonantivirus\ccavmail.dll
    A Nexessary component ect ect
    C:\programfiles\nortoninternetsecurity\ccemlflt.dll
    Any ideas where i can manually delete the boot looking for these programs and hopefully then i can reinstall NIS
    I Would Format hard drive and start again but this is a PCworld PC and ME came preinstalled and don't have a hard copy
    Fatboy
    5,668
    Re: Computer Crash !!!!!!
    Hi Raymond
    if you have deleted the program then the reference to it is generated from the registry. You have to go in to the registry now and delete all references to the file - but as you have limited computer skills/knowledge, I would get someone else to do it for you.
    Oct 2004
    Scotland
    1,454
    As Frank says there is still a entry in the registry.
    All you have to do is delete it. Easier said than done, you could search through and find them all yourself...
    Goto 'START , RUN, and type regedit.
    But stuff that... get a registry cleaner.
    Also get a decent anti virus, can`t beleive you are still running on ME.
    Ill PM you
    Chillin
    and go get a cuppa
    Jan 2003
    East Anglia
    1,160
    Quote Originally Posted by chillin out
    Ill PM you
    Chillin
    Hi Chillin,
    Thanks, Got yoyre PM, working through them
    Was running NIS 2005, subscription run out, re subscribed and thats when it all went wrong.
    subscription date when back to 1899 o it wouldn't bring the box up to enter subscription code and on and on fron there. Tried to remove and reinstall and all gone tits up.
    Still find ME ok for what i do, although slow and full of bugs does the job (JUST)
    Fatboy
    Oct 2004
    Scotland
    1,454
    How much does it cost?
    Chillin
    and go get a cuppa
    Jan 2003
    East Anglia
    1,160
    Chillin
    £32 for another 12 months.
    Another waste of money
    Fatboy
    Jan 2003
    East Anglia
    1,160
    Hi Guys,
    Just to give you an update.
    Just done a scan at freeregistryfix.com and its found over 900 items and yes there were loads of norton files tucked away.
    Fatboy
    5,668
    Found this on another forum.
    Kramer and other members promoting water cooling- you have alot to answer
    I decided this weekend to try and quiten my PC by following some other members lead and going down the water cooling road. The fans on my PC were really starting to drive me mad
    The first thing that I did was to remove all the fans. The one on the processor and graphics card were no problem but the one in the power unit was a bugger to get out.
    The most difficult part was sealing all the ventilitation openings in the PC case with silicon. I also put silicon all around the joints on the PC case. The smell of silicon was dreadful but when my wife complained I told her to be patent as it will be worth it when we have a completely silent PC.
    Because I had completely sealed the PC case the only opening near top was the DVD drive. So I opened that and put the small hose I had purchased specially for the job into the DVD drive as far as it would go. With what I can only describe as great excitement and anticipation, I turned on the water. It really is amazing just how long it took before the case was complete full, and boy was it heavy. That didn't really bother me as I didn't intend to be moving the PC anyway.
    The big moment had arrived so I called in my wife and mother in law (who was visiting) and I announced "prepare to hear nothing!" and flicked the switch on the socket on the wall.
    Before I could even press the power button on front of the PC, with a loud bang, the whole place was plunged into darkness
    I knew that it was only the tripswitch so I told my onlookers not to panic and I ran out to the hall to turn the trip switch back on. But can u believe it, it wouldn't stay on. After five attempts I decided to try unplugging the PC and would you believe...yes the trip switch stayed on. My conclusion: the PC must have in some way been causing the problem.
    After about an hour of tries I finally decided to abandon the whole idea of water cooling and emptied the water out of the PC, put back in the fans (except the fan in the power unit, I had broken that one getting it out) and tried the pc AGAIN. IT STILL CAUSED THE TRIP SWTICH TO BLOW!
    My PC is completely ****ged thanks to stupid suggestions that I got on this forum. What the hell am I going to do now. I spent two hours last night with a hair drier inside the PC case and it still trips the switch.
    Any suggestions greatly appreciated
    Connor
    Member
    Oct 2004
    Scotland
    1,454
    Conor
    What you desperately need is to get a BRAIN.
    What a plonker!!!
    Chillin
    and go get a cuppa
    Oct 2004
    Scotland
    1,454
    LOL... Read the whole post here....
    http://www.avforums.com/forums/showthread.php?t=56924
    What a plonker....
    Chillin
    and go get a cuppa
    Sep 2005
    uk
    499
    that does deserve an LOL.
  1. Liebert computer room units
    By Rick Harris in forum Trouble Shooting
    Last Post: 12-08-2008, 11:27 PM
  2. Amazing Flight Footage of a Crash
    By Brian_UK in forum Chit Chat & Service Stories
    Last Post: 01-02-2006, 02:22 PM
  3. an unique computer
    By halwaya in forum Computers & the Internet
    Last Post: 10-06-2004, 03:42 PM
  4. A/C for computer rrom
    By Reeferjon in forum Air Conditioning
    Last Post: 06-11-2002, 05:55 PM
  5. Computer Rooms
    By vspiteri in forum Industrial
    Last Post: 26-02-2002, 10:51 PM
