    Apr 2012
    Iraq
    35
    623
    how to install desktop PC case fan more effiecintly
    hi
    every body may ask how to install the fan in desktop pc
    how to choose between make it discharge or suck air
    so i found the best way to install fan
    as in image below
    Sep 2003
    ISRAEL
    72
    4,248
    Re: how to install desktop PC case fan more effiecintly
    it sucks the air through the aluminium heat exchanger
    Jul 2009
    South Africa
    79
    195
    I assume the blue arrows are the cold air and the red arrows are warm air. What are the green and the pink arrows indicating?
    Also why does your computer have many more parts inside it than my computer? I'm worried I might be missing some important parts.
    manchester
    5,639
    got a few hard drives there!!- cabling is restricting the inlet fan at the bottom.
    Apr 2012
    Iraq
    35
    623
    number will mean the fan suck or discharge air
    number 1 fan discharge air out
    number 2 fan suck air in
    number 3 fan suck air in
    number 4 fan suck air in
    number 5 fan discharge air out
    number 6 fan discharge air out
    number 7 fan fan suck air in
    Sep 2003
    ISRAEL
    72
    4,248
    you have 3 fans discharge air and 4 sucking air, i think you should have one more discharge fan and all will be fine.
    Are all the fans the same size?
    Apr 2012
    Iraq
    35
    623
    yes the fan are same size
    the photo show you not to install whole fan
    but show you the best way if you want to added fan to your case
    Jul 2009
    South Africa
    79
    195
    Seven fans...wow!!!! If you need that much air movement maybe it would be time to go liquid cooling.
    manchester
    5,639
    just be eco friendly and leave the side cover off
    Apr 2012
    Iraq
    35
    623
    its too bad if you open side cover
    specially in my country
    because dust and sand storm happen oftenly
    Mar 2009
    KZN, South Africa
    64
    2,212
    ROFL... The above comment made my day...
