Results 1 to 8 of 8
Thread: Daewoo Fridge/freezer
23-01-2006, 09:14 PM #1
My fridge freezer is supposed to be "frost free" but ice is building up at the base and my kitchen floor is soaking.
Help please.
23-01-2006, 09:23 PM #2
Re: Daewoo Fridge/freezer
go to ukwhitegoods.co.uk
more suited to your problem
cheers
richard
23-01-2006, 09:31 PM #3
Chances are it'll need defrosting. Despite what the maketing guff says about being frost free there will be times when the freezer will need defrosting such as when the door has been opened many times in humid conditions or the air vents have been blocked by over stuffing the freezer. I normally switch the freezer off, remove the food and blow the wifes hairdrier into the air outlet at the bottom untill warm air blows through the vents at the top. The molten ice will drip down and be directed in to a tray that sits on top of the compressor where the heat from the compressor will cause the water to evaporate, but you may find that when you defrost, the tray will not hold all of the water and will fall on to the floor. This is also a good oportunity to clean under the freezer, you'll be amazed at what you find under there
Karl
23-01-2006, 10:03 PM #4
Help please.
What make is it?
How old?
and go get a cuppa
24-01-2006, 07:45 AM #5
dear
ice in freezer means the defrost is not working
the defrost system is consist of
1-heaters
2-timer
3-overhear thermostat
so one of these components is out of order
check it one by one
good luck
24-01-2006, 10:06 AM #6
Thanks to all of you.Cheers.
03-04-2006, 08:09 PM #7
Have you got it sorted now? I have experience in these
17-11-2009, 08:14 PM #8
Last time i saw this fault the drain in the freezer needed unblocking. the build up of water was over flowing into the freezer where the water froze.
Tricky Service Call to a Fridge/Freezer
By Brian_UK in forum Chit Chat & Service StoriesReplies: 7Last Post: 11-06-2006, 11:34 PM -
Frost free fridge/freezer
By aircon in forum DomesticReplies: 7Last Post: 23-08-2005, 01:33 AM -
freezer section of fridge/freezer has stopped
By roobydoo in forum DomesticReplies: 3Last Post: 30-05-2005, 08:35 PM -
By aircon in forum DomesticReplies: 0Last Post: 21-05-2005, 09:44 PM -
RFI Interference from Fridge/Freezer
By pathfinder in forum Trouble ShootingReplies: 6Last Post: 19-03-2005, 11:50 AM
