Results 1 to 11 of 11
Thread: york ycaa control
12-02-2013, 06:57 PM #1
york ycaa control
I,ve got a york ycaa chiller thats program has changed, i suspect its due to a power cut and the back up rtc battery on the amb board being duff.
The program has changed from chiller to heatpump and only two compressors are enabled one per system instead of two per system.
The question is can the batteries be replaced or is it a new board,and how to reprogram the controller.
12-02-2013, 07:39 PM #2
Re: york ycaa control
Is it an ISN keypad, up/down arrows, options button etc? If so it's similar to the YCCD units, battery is a seperate part no: 031-00955-000 Clock/lit Battery, (for the YCCD)
Had one fail recently, you can reprogram through options button to tell it to be a chiller
alMostly found in the southern part of this green and pleasant land.
12-02-2013, 07:52 PM #3
12-02-2013, 08:58 PM #4
Does the battery just pull off the board position u17 ?
12-02-2013, 09:55 PM #5
If memory serves me then yes, very like the eeprom i think.
And thank Install for the manuals!!
12-02-2013, 10:05 PM #6
12-02-2013, 10:07 PM #7
12-02-2013, 10:35 PM #8
thanks for the lovely message with the bleeps Install haha
I stand corrected its not Grand Papa its GRANDAD
congratulations you old get
anyone else missing york manuals
http://www.refrigeration-engineer.co...ging&highlight=
R's chillermanIf the World did not Suck, We would all fall off !
13-02-2013, 06:46 PM #9
Should have known they were yours CM!!
Thieving granddad, get him an OAP ASBO.
13-02-2013, 07:09 PM #10
Thanks for the info guys much appreciated.
09-05-2013, 04:17 PM #11
Hi im looking for the access codes for a YCCD 20 so I can change the LP set point.
