Results 1 to 2 of 2
    Dec 2010
    Ireland
    339
    15
    Retrofitting 410a on a Propane system
    Recently I've come across a type of heat pump that has serious problems with invertors and compressors and are costing customers a fortune in repairs. Most people have asked me is it possible to retrfit a different heat pump to the existing dx collectors. The problematic systems have been running on propane and were I to switch it would be to 410a. What problems would I face in this scenario with oils and contamination from the propane and is it even feasible?
    Jul 2009
    Australia
    44
    81
    15
    Re: Retrofitting 410a on a Propane system
    Quote Originally Posted by Bigfreeze View Post
    You need to find out why the System did not run well on Hydrocarbons first, was the correct hydrocarbon blend used? Contamination, Air, Moisture? Charge Level?
    Or were the Inverters simply just playing up?
    Propane if that is what was in the system won't cause any defects or contamination to the oil.
    if a Good Quality hydrocarbon blend is avaliable locally that will replace the original Fluorocarbon Gas, there is no problem using that, either way once you get some refrigerant in there you'll have to diagnose it once the inverters are replaced, do you suspect any other problems?
