Results 1 to 8 of 8
    Nov 2006
    West Texas, U.S.A.
    75
    Texas Seeking Info on HC Refrigerants
    Howdy from Texas. Well, looks like the US is opening up limited use of HC R290 and R600a.
    I would really appreciate some advice/info from you guys on best practices, types of
    service equipment/tools you use in the service of this equipment. Recovery, Evacuation,
    Service connections etc. I know you are well ahead of the curve on these refrigerants
    and am hoping to glean as much info as possible. Any help, Info, In-sight would be greatly
    appreciated. Many Thanks,
    GF
    Oct 2007
    manchester
    5,639
    45
    Re: Texas Seeking Info on HC Refrigerants
    11,025
    In general they are just like any other refrigerant in the need for safe and careful handling.
    The recovery machine obviously needs to be suitable for HC use. Another tool which is semi-critical is having a combustible gas leak detector operating near you when you are breaking into a system for any reason. The type used by a gas fitter is quite good enough.
    If working on a system always recovery and then purge through with nitrogen before any brazing work.
    Nov 2006
    West Texas, U.S.A.
    75
    Thanks for the replies. So I would assume that due to the small
    quantity of refrigerant in the systems, an empty cylinder with a
    deep vacuum would be suitable for recovery. Nitrogen purge, make
    what repairs were required, evacuate and recharge?
    It is my understanding that the service ports shall be of a different type.
    I assume maybe left hand, smaller, larger etc. Is that the case over there?
    Do you know of a recovery machine that is approved? Make model etc would
    be appreciated. Not finding much on mfg data here. May not be looking in the
    right place.
    Do you find most troubleshooting to be done with Temp diagnostics? I would
    assume as with any machine, hosing up is a last resort?
    Again, Many Thanks.........GF
    11,025
    Haven't found any difference in service port sizes, usual 1/4 flare hose connectors. Rest of your comments are good.
    Nov 2006
    West Texas, U.S.A.
    75
    Thanks for the input, I really appreciate it.........GF
    May 2012
    59
    1,528
    36
    The difference with HC refrigerants as apposed to the others (in the UK anyway)
    is we are allowed to vent it to atmosphere.
    It has to be done in a controlled manner and there are limits to this but because
    of the low GWP, we can vent it.
    On a Data sheet from one manufacturer they recommend disposal as flaring it off.
    Burning it in other words and I have a propane Bunsen-burner and demonstrate this
    to students by connecting it up to the fridge and burning the gas(**).
    The biggest worry with the gas is the electrics. Normal electrics with switches may
    not be suitable for HC refrigerants unless they are removed up and out of the way
    of the gas or are inside sealed units to prevent gas ingress. If the electrics are to be
    potentially in the gas then they tend to be solid state..
    (**needless to say there are severe safety implications to this and flash back arresters,
    correct equipment and full risk assessments have been carried out first.
    Do not do this without full risk assessment beforehand, in fact DON'T ever do it
    and never say Rob told you ).
    Rob
    Jun 2010
    Yorkshire
    59
    520
    Yes like Rob says don't do it. But if you do, connect your hoses to a purging stack/bunsen burner, and set your guage pressure to 0.55 psi and make sure you do it outside!
    Training may be finished but experience is never complete.
