Results 1 to 15 of 15
    Feb 2013
    Ukraine
    49
    9
    compressor failure Hall Screw 4221
    Good day!
    Ask for advice on the compressor
    After 3 years of operation of the compressor started to warm up. After dismantling babbit found flaking on the drive shaft and rubbing on one of the Capacity Control Slides.
    Because of what it could be? The compressor runs on ***** 134, cools glycol.
    By the way, who knows what they are covering the edge of the shaft babbitt?
    Feb 2013
    Ukraine
    49
    9
    Re: compressor failure Hall Screw 4221
    Feb 2013
    Ukraine
    49
    9
    Jun 2011
    Australia
    44
    336
    21
    http://www.halltherm.com/
    I say get a new / rebuild compressor. The hassle & liability of trying to repair that kind of damage is too much. Be sure to check for liquid slugging & correct operating pressures / temperatures - that kind of damage in 3 years points to a problem with compressor operating conditions.
    Feb 2013
    Ukraine
    49
    9
    Working pressure of 134a ***** rarely rose above 9 bar.
    In this compressor had problems with the evaporator: rotten pipe and glycol got into the ***** part.
    Feb 2013
    Ukraine
    49
    9
    The fact that this is a semi-hermetic compressors and spare parts to it do not sell. At least, that's explained in the Ukrainian representative
    Somerset
    69
    4,713
    Lack of lubrication = abnormal wear.
    You can hardly blame the compressor if the refrigeration circuit got flushed with Glycol.
    I am not sure of your comment about spares but as far as I know J&E Halls spares network is excellent.
    I can't comment upon the price though!
    Which is all irrelevant as the comp is not designed to handle Glycol!
    Feb 2013
    Ukraine
    49
    9
    Thank you, I understand your point.
    In your opinion, the Capacity Control Slides should be changed?
    Why Manufacturer afloat Babbitt on the drive shaft?
    Feb 2013
    Ukraine
    49
    9
    Yes, this is the problem: given a tube evaporator leak.
    495
    21
    Hi i think the babbitt is there to protect the main shaft and body rubbing together and causing expensive damage, when the babbitt comes off the compressor it does,nt pump,eg when bearings wear ,or screw over heats it gets shaved off or peels instead of rubbing and grinding into the body. the gap between the body and screw is about 4 thou and the repair is easy for manufacture ,just spray or use other method to put babbitt on the screw.
    hookster's Avatar
    hookster is offline Veteran Poster I am starting to push the Mods: of RE
    Apr 2007
    Hampshire
    438
    32
    Hi are you sure that it is Babbitt? I would personally assume that it is pick up from micro seizure as the lubrication film breaks down either from flushing or tolerance changes as the liquid entered compressor.
    You can check if it is Babbitt (White Metal) by scraping some and testing if magnetic.
    Feb 2013
    Ukraine
    49
    9
    Yes, it is 100 % babbit.
    Feb 2013
    Ukraine
    49
    9
    Who can tell you where you can buy the main rotor? Repairing the damaged rotor exempt. I would like to hear the opinion of the representative J&E Hall.
    Thank you!
    Aug 2007
    42
    135
    Yes it is a white metal covering, hit with ball bearings to increase oil pickup. Do not rebuild this machine its not worth it. Just buy a new one from spares distributor. Oh and fix the evaporator and new oil charge etc....
    Just seen pics too, you'll need to replace bearings and slides too as bearings have dropped and caused the damage seen.
    The Bridge Keeper
    'Answer me these questions three, n'er the other side ye see.'
    What is your name?
    What is your favourite colour?
    What is your suction superheat?
    Oct 2001
    Barranquilla , Colombia
    74
    31
    I know similar cases and treated "Plating" waste when synthetic oil reacts with water and pipe heat exchangers and other metal surfaces forming a paste.
    On my desk I have a rotor of J & E Hall to work weeks without oil . It is the best refrigeration compressor .
    Suggest clean all parts , replace bearings and stars in fiber. . . and ready
    Please , see www.cbarrantes.com/english.html
