Results 1 to 13 of 13
    hookster's Avatar
    Apr 2007
    Hampshire
    438
    32
    J&E Hall Reciprocating compressors V178 (7” X 5 1/2”)
    Has anyone got a service manual for this compressor, that they would like to share?
    495
    Re: J&E Hall Reciprocating compressors V178 (7” X 5 1/2”)
    Hi hookster its same as v127 but alot bigger.ive got wesr tolerances and apares manual.
    What are you doing to it. A top end valve change or complete strip down. Let me know and i will tell you the best way of doing it.because if done wrong the parts cost s fortune.
    hookster's Avatar
    Apr 2007
    Hampshire
    438
    32
    Hi GHAZ
    Top end and shaft seal, but I would like to know any other pitfalls for future reference.
    Good looking machine! and a lovely big Thumper the old recips, just wish customers would stop ripping out the decent equipment to fit cruddy chillers!!
    495
    when you change the discharge valve and springs ,and get ready to put it on . make sure the unloader sleeve pin are down ,because if not they will get bent, the best way if you hav,nt got compressor tools is get some body to push the rod in and you will see the pins drop.put the both discharge valve assemblies on and then the springs and then gasket and the head and tighten it down ,still with the rod pushed in, once the head is tight with 2 bolts you can release the rod. the shaft seal is fairly easey ,measure the distance from the shaft and then put it back same distance it is held on by grub screws. if you are stripping the liners out you need to take out push rods first and lable them to which cyclinders they go and then take liners out
    495
    hi hookster ive sent you tolerances sheet and a picture but your email domain reject it.
    May 2012
    59
    1,528
    Quote Originally Posted by hookster View Post
    Hi Hookster.
    I've been looking through all my old manuals
    and I have full detailed copies of the
    7" x 5 1/2"
    5" x 4"
    V92 3 5/8" x 2 5/8"
    VP & VPC Stern
    Lubrication specs for Grasso
    I can only do paper copies at the moment because, combined there is over 500 pages.
    I could copy them and post them to you if you PM me an address (I'll do it Monday).
    I will then look at scanning them and saving them as a Pdf files for wider use
    Rob
    May 2012
    59
    1,528
    I have also found a full training manual from 1972 that covers
    refrigeration training for the whole J&E Hall range and then it goes
    into the manuals for the
    V54
    V92
    V127
    V178
    It also explains how to make Calcium Chloride Brine and how to make up
    and the maintenance of methanol or methylated spirit and water.......
    It then goes into the method statement for a liquefaction plant in Kwinana in 1965
    (where ever Kwinana is?)
    Rob
    4,697
    You must of been a child engineer Rob!
    I bet all the temps are in Fahrenheit?
    May 2012
    59
    1,528
    Suckled on Ammonia
    Fahrenheit and an obscure unit called the BTU
    Old money
    Rob
    Dec 2011
    EAST OF ENGLAND
    38
    27
    into the manuals
    To Rob, I would also appreciate copies of any Training documents & Manuals you could copy when you get chance.
    I'am trying to save any relevant reading material that will be of help to my learning.
    I'm trying to read through something every night at the moment.
    Thanks From CO
    manchester
    5,639
    http://en.wikipedia.org/wiki/City_of_Kwinana bit of geography for you rob
    V54
    V92
    V127
    V178
    Rob
    May 2012
    59
    1,528
    Kwinana is a Kimberley Aboriginal word meaning either "young woman" or "pretty maiden".
    Nive.....
    Rob
    May 2012
    59
    1,528
    Charlie-Oscar
    I will get them scanned and saved as pdf documents
    and then I will either post them with somewhere on the web
    or if small enough email them out.
    I'll get back to you.
    Rob
