Thread: Cascade -90 C
    Mar 2012
    italy
    75
    Cascade -90 C
    Greetings to all
    I retrofitted a unit cascaded to the second stage with a final temperature of -90 C. the system had a load of 1 kg with 0.1 kg R503 R12.
    I replaced the oil with oil poe, and primed, 1 kg 0.1kg R23 with R134a.
    after the test run the final temperature reaches -65 C.
    can someone help me with similar experiences?
    which you think may be the right mixture of refrigerant retrofit?
    Thank you.
    Mar 2012
    italy
    75
    Re: Cascade -90 C
    experts please help me.
    & thanks in advance
    Mar 2006
    Merate (LC) - Italy
    2,553
    Re: Cascade -90 C
    With R134a is quite impossible to reach -90C.
    You had to use R23, but then again it is impossible to say, unless you give complete description of components, exchangers and compressors of the two stages.
    Oct 2012
    Russia
    36
    390
    12
    Re: Cascade -90 C
    You can use ethylene for 2 steps, if you find)
    Mar 2012
    italy
    75
    Re: Cascade -90 C
    Thanks for the answers
    What do you think if I use the refrigerant R508B?
