Results 1 to 17 of 17
Thread: samsung
    rbartlett's Avatar
    rbartlett Guest
    samsung
    Anyone seen one of these things?
    Got a call 2 days ago from a school near oxford to say 'it's not cooling'
    it was installed by a company who lost the contract for oxfordshire so they couldn't get hold of them
    i went to site and found some kids had turned off the isolator on the roof.
    i switched it back on and it run..a-okay no problarmo nice little earner ;-))
    today I got another call saying it runs but it's not cooling,so I popped in on my way home...
    up on the roof found the unit less than a year old and the 4way valve split and dumped it gas
    I showed the customer who spotted the 'made in china' label on the valve and just sighed...
    cheers
    richard
    rbartlett's Avatar
    rbartlett Guest
    Re: samsung
    Quote Originally Posted by Marc O'Brien
    It's probably an air conditioner, Richard. The 4-way valve means it's likely a heat-or-cooling air conditioner.
    There would have been another half to it located indoors within close proximity to an area they wish the air to be conditioned.
    I've come across these things before.
    Okay that certainly narrows it down.. I had already eliminated digital camera AND a TV so I was getting close to a sloution..
    however providing you are right (you didn't seem too certain) we can move the conversation on to the possibility that they are s.h.i.t.e quality..
    cheers
    richard
    Oct 2001
    Nottingham UK
    5,668
    Re: samsung
    Are you sure the gas leaked out of the 4 way valve?
    It could have leaked out of the hole on the lid where the screw is missing
    Nov 2005
    Southampton
    45
    54
    Re: samsung
    I think that samsung were distributed by SWM until last year.
    you may get info from them (branch in Eastleigh Hants)
    Jun 2005
    Stoke on Trent
    588
    Re: samsung
    Ambient Technical Solutions in Stoke on Trent were recently appointed dealers of Samsung, they have been trying to get me to buy Samsung for ages now, I much prefer Fujitsu.
    Oct 2004
    Scotland
    1,454
    21
    Re: samsung
    I had a 4 way valve split on an Airwell before, It had cracked where the pipe joins the brass body.
    Chillin
    and go get a cuppa
    rbartlett's Avatar
    rbartlett Guest
    Re: samsung
    well for two reasons i may well just cut it out
    1 it's in a server room so no heat is req'd
    2 there is no warrenty so they would have to buy rev. valve and it's redundant -see 1
    cheers
    richard
    Oct 2001
    Nottingham UK
    5,668
    Re: samsung
    Be careful with that Richard
    We had a Tosh doing a server room and the coil had burnt out - as it was critical to keep the thing running and the coil was energised for cooling, our eng took the decision (9:30 at night) to reclaim and cut the valve out.
    Well, no problems so far and for about 7 months - then we get the call "it's hot in the room and the AC's not working."
    Off to site - guess what - the systems fine - it's just that some plonker had set the controller to heat mode and so the unit just sat there.
    The indoor coil sensor was expecting a temp rise within a certain time before the indoor fan was allowed to run and when it didn't come the system just continued to run in cooling and the whole thing iced up (indoor)
    rbartlett's Avatar
    rbartlett Guest
    Re: samsung
    valid point frank for sure but if someone set the unit on heat and the valve was still in place the unit would have heated up the room.
    no i think i shall naturally inform and get consent but i feel it's the best course of action. + a big "do not touch the controls" sign should absolve any responsibility to all apart from the person who ignores it
    cheers
    richard
    Oct 2003
    5,630
    34
    Re: samsung
    The green sticker, isn't that a Saginomyia 4-way valve?
    If so, it's Japanese and part now of the Danfoss group.
    Daikin and Mitsubishi and many others are installing the same brand. We use it also in the market trucks.
    Where was it ruptured?
    Sep 2005
    uk
    499
    21
    Re: samsung
    complete barking madness. need i say more?
    Takes a licking, keeps on ticking.
    rbartlett's Avatar
    rbartlett Guest
    Re: samsung
    Quote Originally Posted by Peter_1
    yes, but it also has a 'made in china' sticker on it..
    I didn't have any nitrogen on me and it was completely flat so i only has the oil as evidence..
    however i shall return and see exactly where it was leaking from
    cheers
    richard
    rbartlett's Avatar
    rbartlett Guest
    Re: samsung
    popped back today to PLT the system
    found it was the Rv leaking at the centre pipe as it enters the brass body
    anyway I did what i thought I'd do and the customer is happy
    cheers
    richard
    Dec 2005
    Spain
    61
    Re: samsung
    M Marc do all your customers look like that!!!!
    Do you have any jobs going !!!!
    :cool: Calvo :cool:
    Dec 2005
    South East England
    56
    155
    Re: samsung
    What's that hanging down between the first woman's legs (I'm assuming it's female)
    Good stuff, another happy Fridgetech customer. For those members who have never seen a happy Fridgetech client I've included a few shots to illustrate just how animated a happy Fridgetech client can be:
    Noah had to leave the dinosaurs behind as they would've sunk the boat.
    rbartlett's Avatar
    rbartlett Guest
    Re: samsung
    exactly the same..
    cheers
    richard
    Dec 2004
    Weihai,China
    800
    Re: samsung
    At Fridgetech we discourage all forms of discrimination. So we won't be justifying that question with an answer.
    I admire it. It's my dream to work in this kind company
  1. Samsung Error codes
    By kevscontent in forum Fundamentals
    Last Post: 04-04-2011, 08:08 AM
  2. Samsung Error codes
    By kevscontent in forum Trouble Shooting
    Last Post: 08-08-2010, 06:20 AM
  3. samsung
    By superswill in forum Trouble Shooting
    Last Post: 20-07-2006, 09:20 PM
  4. Leaky Samsung...
    By charliepad in forum Domestic
    Last Post: 08-07-2006, 12:54 AM
  5. Samsung Domestic nightmare
    By andre_fridge in forum Domestic
    Last Post: 31-05-2006, 10:48 PM
