Thread: danfoss oil regulating valve
30-01-2013, 10:13 PM #1
hi all,
i have a problem with a oil regulating valve Danfoss ORV 25-80. I just need to replace the gasket thats under the top inspection cover that seals this cover(aswell as 4 17mm head bolts)
Is this size gasket easily available? I will investigate in morning when suppliers open. These valves are often not off the shelf so am a little worrried.
Thanks in advance,
30-01-2013, 11:12 PM #2
Re: danfoss oil regulating valve
Parts list here, might help???
http://www.ra.danfoss.com/TechnicalI...P0A302_ORV.pdfBrian - Newton Abbot, Devon, UK
30-01-2013, 11:17 PM #3
thanks brian, hopefully its off the shelf from suppliers
30-01-2013, 11:20 PM #4
May not be off the shelf but hopefully small enough to be put in a padded envelope for speedy delivery. I know, we live in hope.
31-01-2013, 06:33 AM #5
Hi Gary.
These are usually available subject to delivery within the UK as Brian states.
I cant advise as to what the case is within your fair isle?
Is the valve that you have presumably overhauled, very old?
