Results 1 to 1 of 1
Thread: Tyler ceiling brackets
29-01-2013, 01:57 PM #1
hi there, I'm installing a large cooler, 20x30x8feet. used, Tyler. I can't figure where to buy these missing ceiling brackets. I have 2 beams (20' long) that go across top of ceiling and there should be a way to suspend the ceiling onto them. This is an old cooler, maybe 15 year old, manufacturer said they didn't have computerized system at the time and can't pull the specs from the model #. the beams sit 4 inches above ceiling running on width (20') resting on the top of side wall with a reversed "T" type of bracket ___II___ any suggestions would be appreciated, thank you
