Results 1 to 10 of 10
    3,853
    NTC temp probe availability?
    I need a couple of 50K NTC temp probes (water proof) for a chiller. Any ideas where i can get some off the shelf or a company that will make them to spec?
    I need to get this running again asap, waited a couple of weeks for parts from main agent and then it turned out to be the wrong part!
    Might try making some, thermistors dirt cheap from RS...
    Jon
    Feb 2009
    telford
    2,090
    33
    Re: NTC temp probe availability?
    rewl denton manchester
    Feb 2008
    502
    21
    try climet center or thermofrost
    Feb 2008
    502
    21
    rs componants
    Oct 2001
    Nottingham UK
    5,667
    Just what you are looking for Monkey http://www.ebay.co.uk/itm/10pcs-NTC-...ectorid=229508
    Oct 2007
    manchester
    5,639
    45
    climate ctr- do titan and electro sensors, any type, just tell em the resistance at a few temps, probe diameter and length of flex, I got an air sensor for a York- 9 quid!
    hookster's Avatar
    hookster is offline Veteran Poster I am starting to push the Mods: of RE
    Apr 2007
    Hampshire
    438
    32
    3,853
    Thanks for the replies!
    Jul 2009
    Latvia
    35
    49
    What does this nr. on temp probe mean 3K, 50K? I need a 3K sensor, how does temp.-resistance grapg look?
    3,853
    It generally means the the resistance will be 3k ohms or 3000 ohms at a set temperature like 20C or whatever the manufacturer has used as reference temperature.
    Heres a chart i found,
    http://www.veris.com/docs/support/fa...Z202030-0N.pdf
