Results 1 to 14 of 14
    Jan 2004
    Queenstown, New Zealand
    48
    Necchi Compressors?
    Hello,
    Looking to find a supplier for Necchi compressors? any ideas?
    Necchi ESM 5 (30044)
    rbartlett's Avatar
    rbartlett Guest
    Re: Necchi Compressors?
    my understanding is that necchi ceased production many years ago..
    cheers
    richard
    Nov 2005
    New Zealand
    550
    http://www.alltemp.ca/pdfs/Compressors_2000.pdf Hi, You can maybe can cross reference with another type try that site above or search google.
    Regards toosh
    Oct 2003
    5,630
    34
    They went bankrupt.
    Problem is that a replacement compressor is mostly many times a lot heigher then a Necchi and doesn't fit in the available space.
    Oct 2004
    Scotland
    1,454
    21
    Thats cos they were $hite, the relay`s were always going on fire.
    Chillin
    and go get a cuppa
    Jan 2004
    48
    Many thanks guys...........couldn't find anything on them really on the net...........possibly cost of comp is too high compared to cost of new fridge
    May 2003
    Edmonton alberta Canada
    95
    22
    do you have a mod number or capasity or frig size can sometimes gues at btu s
    wesmax
    Wes Maxfield
    Jan 2004
    48
    model number Necchi ESM5 (30044) it's on a fridge freezer
    http://www.iran-compressor.com/esm5h.htm
    is the nearest I can find
    Mar 2004
    624
    21
    This company should help you
    Cooltech 0141-883-0447
    Regards Bernard
    expertcat's Avatar
    expertcat Guest
    wouldnt trust a necchi due to the relays catching fire.
    as long as you have the cubic capacity 90% of compressors should fit.
    we always used aspera compressors as they fitted ok with all the different makes i worked on.
    The only compressors which we had was danfross crap that wouldnt fit into hardly any units.No wonder candy sold them on.
    Jan 2006
    newcastle upon tyne
    12
    hi
    try a company called carrs they are in stoke on trent or there abouts. they supply refrigeration spares and compressors
    May 2006
    Serbia
    13
    Necchi 5 has 5cm3 volume! Replace it with Danfoss TL 5, or similar.
    Jun 2005
    Stoke on Trent
    588
    Use a Embraco EM, they are very small, I use a lot of them in tight spaces.
    May 2003
    95
    22
    have you ever tried the Americold brand these are used a lot on oem slush and small coolers.
    wesmax
    Wes Maxfield
  1. Price Of Refrigeration Compressors
    By justin4236 in forum Supermarket Refrigeration
    Last Post: 08-09-2005, 01:38 PM
  2. Time delay for multi compressors
    By iceman007 in forum Air Conditioning
    Last Post: 06-11-2004, 08:05 AM
  3. Compressor's volume efficiency
    By John McGru in forum Fundamentals
    Last Post: 16-02-2004, 08:44 AM
  4. Comparative compressors
    By Friobernal in forum Technical Discussions
    Last Post: 28-04-2002, 07:21 PM
