    Jan 2013
    uk
    38
    5
    hi new to this i have a couple of questions about presure temp
    hi there ,
    I am studying at the moment and have loads of questions the first one is about pressure temp
    on my chart for pressure temp it tells me that at 0oc the pressurre of r134a is 2.98 bar
    which is straight forward enough , but if my gagues tell me that the suction pressurre is 2.98 bar and my temp is zero in my evaporator were it is changing phase what will my air off be , it wont be 0oc
    is there a rule of thumb to tell you what your air off will be
    for example i want my freezer down to minus 10oc what pressurre would i want my r134a at to get me that temp
    May 2012
    59
    1,528
    36
    Re: hi new to this i have a couple of questions about presure temp
    Quote Originally Posted by superduke View Post
    hi there ,
    The evaporator is always the coldest and we normally work to a Rule of Thumb of 10degs difference.
    The evaporator will be about 10 degs colder than the air off the evaporator.
    If you want a case temp of -10 degC then you will be evaporating at approximately at -20 degC.
    But in your calculation you have mixed up gauge pressure and absolute pressures.
    We measure scientifically in pascal's (named after the guy who invented pressure )
    and there are two pressures there is the absolute pressure and then there is gauge pressure.
    Gauge pressure would show zero if you open your gauges up to the air you are stood in (under normal atmospheric conditions), but absolute would read 1 bar (or 100,000 and a bit pascal) so if you are looking
    on a compariter don't confuse the two pressure.
    Gage pressure is always the lower of the two and that is the one you use to measure the working system.
    Your 0 degC at 2.9 should be 0 degC at 1.9 (2 bar to you and me) when reading on a working system
    using gauges.
    Your "for example i want my freezer down to minus 10oc what pressurre would i want my r134a at to get me that temp"
    Case temp -10 degC = evaporating at about -20 degC = pressure of 0.3 to 0.4 barg.
    Rob
    Jan 2013
    uk
    38
    5
    aha that is superb , thank you very much .
    Jan 2013
    uk
    38
    5
    and bar gauge as well i had not factored that in .
    May 2012
    59
    1,528
    36
    Nice one.
    Rob
