Thread: Power factor?
    Apr 2008
    Tasmania
    216
    Power factor?
    In one sentence can someone explain power factor with reference to reactive, real and apparent power? Or maybe two sentences
    The more I learn the less I know......
    Oct 2007
    manchester
    5,639
    45
    Re: Power factor?
    Last edited by install monkey; 20-01-2013 at 10:31 AM. Reason: brian taught me well!! haha
    Apr 2006
    55
    1,908
    30
    Re: Power factor?
    with high power factor current/voltage waveforms are syncronised
    with low power factor they are not and cause higher amp draw
    R's chillerman
    If the World did not Suck, We would all fall off !
    Oct 2007
    manchester
    5,639
    45
    Feb 2009
    telford
    2,090
    33
    Re: Power factor?
    fit more save the planet!
    Apr 2011
    India
    36
    94
    14
    Re: Power factor?
    P = ROOT 3 * V * I * PF (COS #)... #= Angle between Current and Voltage. Current can either lead or lack voltage vice versa.Both lagging and lacking are not desirable and this angle should be minimum.Optimum power factor is one that is angle between current and voltage is zero, so cos 0 = 1.
    The advantages of optimum power factor is already explained by Chillerman i.e les amperes drawn, better efficiency..
