Thread: Clean Burnt Out Tube Chemical
19-01-2013, 05:33 PM #1
Hi friends
Actually i want to clean out Copper tubes which contain lot of carbon burnt out particles and other contaiminates. I tried with direct flushing but all in vane..So any body could suggest me a good cleansing agent which can clean all evaporator tubes especially long Condenser tubing?
19-01-2013, 05:36 PM #2
Re: Clean Burnt Out Tube Chemical
honeywells R245
R's chillermanIf the World did not Suck, We would all fall off !
19-01-2013, 05:49 PM #3
is it comapaitible with R134a?and will it disperse when come in contact with air?
19-01-2013, 05:51 PM #4
its boiling point is just below 16*c so will totally vapourise
good cleaning solvent with similar uses as R11
19-01-2013, 07:20 PM #5
19-01-2013, 09:47 PM #6
you can put it in a jug/drum and pour it in
it will boil off at first but once tubing is down below 16*c it will run as liquid ok
or cap the end plus add shraeder
its a degreaser/solvent so will clean thoroughly and can then pour it out when done
any residual will vapourise
20-01-2013, 04:02 PM #7
Thanks Man...Il try out
