    May 2009
    Portugal
    14
    I/O modem to use with phone line
    Hello everybody,
    I´m searching some time ago for a PCB card or a modem with some I/O contacts, which might allow to connect and control thought a phone line.
    The main idea is with those contacts be able to turn on/off and also status of an equipment remotely.
    I know that Siemens add some time ago something of this type, but so far I was unable to find it from that brand or other.
    Can someone give me a clue of some manufacter or model?
    All the best
    Aug 2001
    Nr Manchester, UK
    54
    36
    Re: I/O modem to use with phone line
    http://www.roundsolutions.com/shop/p...oducts_id=2209
    This is a GSM one with some digital inputs along with a relay output. There are sure to be others somewhere.
    May 2009
    Portugal
    14
    Thanks a lot!
    Jun 2009
    Lusk , Dublin
    1,115
    Developed for Mitsubishi electric but i'm sure it could be adapted ,allows you to control all settings and monitor alarms by SMS texting.
    Procon™ Micro (M2M-SMS-A/08)
    Stu
    Tool's ? check ! Condom's ? check !
