Results 1 to 14 of 14
    Oct 2005
    In a 2 bedroom unit. Why's That? :)
    314
    UV Dye leak detection additive in large systems
    Hi guys, I have a freezer room with a nuisance leak that I can not find. THe system has a bank of 3 large Bitzer semi's on it and holds a refrigerant charge of about 95kg of R404a.
    Is it safe to use moon shine or another leak detection additive in such a large system?? I know it would have to be charged into the high side of the system to reduce the amount coming back through the oil sep and logging in the compressors.
    1 Engineer has told me NOT to use such an additive.. What is the thoughts of the RE community?
    Dogma
    May 2012
    59
    1,528
    36
    Re: UV Dye leak detection additive in large systems
    I'm in two minds about the stuff.
    Personally I hate any make and all makes of leak detection additive.
    I have used them in the past and they have caused more problems than
    they solved.
    In my opinion you should never put anything into the system that the
    manufacturer does not put in and they don't come supplied with the stuff.
    That all said and done, they do work and they do find leaks.
    My experience with them is in supermarket packs and these leak detect dyes
    caused no end of problems with oil return, valve's choking, and acid.
    The supermarket packs were a bit leaky and there was sometimes a moisture
    problem which was bad enough, combine that stuff and it was like "light the blue
    touch paper and stand back" took a long time to rectify lots of niggly faults that
    showed up afterwards.
    One good thing they are great for........
    Mark the apprentices forehead with the stuff and watch him glow in the night club
    Not that I would do that to any one (much)
    Rob
    Feb 2009
    telford
    2,090
    33
    i guess overdosing the system would be the main issue
    Sep 2003
    ISRAEL
    72
    4,248
    I would recover all the refrigerant and pump it with OFN + helium,than with patience and soap find the leak.
    Oct 2007
    manchester
    5,639
    45
    if you put spectroline dye in the system you will find all sorts of leaks,but on the negative side, you'll get covered in it, and everyone elses gauges will get covered in dye, if found tricky leaks on compressor terminal plates,bellows on pressure switches,end plates on evap coils, flare nuts when operating under normal conditions.
    Aug 2008
    Auckland
    55
    259
    21
    Less is more with this stuff! Patience and proper procedure when inserting. It is great for finding leaks. Maybe offer a oil change on compressor down the line to dilute the stuff once you have found your leaks...
    Oct 2005
    314
    The biggest problem I have is the twin evaps are 24 feet off the ground..... and at -30 deg. C is slippery and dangerous work on a ladder or in a forklift bucket....
    Mar 2010
    usa
    120
    Im not a fan of any additives. I had 1 Rack with a Dye in it, cant say I found any more leaks from the Dye than with a Electronic Leak detector.
    ireland
    54
    275
    26
    When this stuff came out first i seen it seize a big bitzer ,granted too much was put into the system. I have also seen it block alot of expansion valves.point being it sticks to everything even moving parts.I would not use it in any system,also doubt if warranty would be honoured if you sent a compressor back with that stuff stuck to it
    Feb 2009
    telford
    2,090
    33
    fork lift buckets are not allowed anymore
    ireland
    54
    275
    26
    As bart simpson said it wasnt me,but in fairness to the guy he put in what supplier told him,as regards the blocked valves it was the correct amount,no fun pulling valves at 3 o clock in the morning
    Jan 2006
    Norway
    1,042
    4
    31
    We have been using it on a R-507 system with a 3000 kg charge of refrigerant, it's been running for 10 years now with no problems.
    The biggest issue with the dye is that some people think it's universal and that is what causes problems. As long as you find a dye that is compatible with both the refrigerant and oil you are using (not just one of them ), you shouldn't experience any problems.
    The downside with it is that it gives the oil a very "distinctive" smell, and that any oil spill in the machinery room is harder to clean up unless the floor is painted
    -Cheers-
    Tycho
    Jun 2010
    Yorkshire
    59
    520
    If you have a long horizontal run like you have and its high up and the floor is slippery. The die would be the best option, if you don't spot the leak straight away, it will eventually start to come through the armorflex. Especially if the joints haven't been flagged and the installers have used up all their **** ends of pipe.
    One of the guys that I laboured and was apprenticed to years ago, would have me rast and joint 2 foot long **** ends of pipe. Luckily because I was conscientious with brazing, they didn't leak. Which was just as well as they weren't flagged where they were.
    Training may be finished but experience is never complete.
    Aug 2012
    united states of america
    1
    i have used my h10 to find many impossible leaks, if you can shut it down and recover 404, put 20# r22(soo sensitive to h10) in and pressurize, shut off suction bvs and let equalize at 300# with patience you will find leak
Tags for this Thread
