Results 1 to 15 of 15
    Feb 2012
    libya
    41
    94
    13
    Expansion valve equivalent
    Dear all,
    What is the equivalent Danfoss Expansion valve for ALCO:
    XC726HW100-2B
    MOP code/100
    Operating range/+13....-45°C
    R22
    Orifice:X9117-B7B
    Regards&Thanks
    Email: r.e951@yahoo.com
    Oct 2007
    manchester
    5,639
    45
    Re: Expansion valve equivalent
    ALCO T-SERIES TAKE-A-PART THERMO VALVE
    T-SERIES TAKE-A-PART VALVE LARGE CAPACITY 22 TO 100 TONS (R22 NOMINAL – BALANCED PORTED AND
    BI FLOW)
    STEP 1: SELECT CAGE FROM CAPACITY TABLE
    NOMINAL CAPACITY — TONS CAGE ASSEMBLY
    PART NO VALVE TYPE R-22 R-507/R-404A R-502 R12 R134a R407C 1 PART NO 1 DESCRIPTION
    ALC-077896 * TER 22 14 14 13 16 22 ALC-077896 * X9117B6B
    ALC-078117 * TER 26 16 16 15 19 26 ALC-078117 * X9117B7B
    ALC-071155 * TER 35 21 21 20 25 35 ALC-071155 * X9117B8B
    ALC-029429 * TER 45 27 27 25 31 45 ALC-029429 * X9117B9B
    ALC-070738 * TIR 55 37 37 35 45 55 ALC-070738 * X9166B10B
    ALC-071238 * THR 55 37 37 35 45 55 ALC-071238 * X9144B10B
    ALC-020846 * THR 70 48 48 45 55 70 ALC-020846 * X9144B11B
    ALC-021067 * THR 85 60 60 55 68 85 ALC-021067 * X9144B13B
    ALC-065123 * TMR 100 60 – 55 68 100 ALC-065123 * X9144B14B
    NOTE: Nominal capacities shown here are based on 40°F evaporator temperature and 100°F
    vapor-free liquid refrigerant entering the valve. R-12 and R-134a rated at 60 PSID.
    All other refrigerants rated at 100 PSID.
    (1) Gaskets included on cage.
    Gasket strip X13455-1 (PCN: 027579) replaces all older T-series gasket kits.
    STEP 2: SELECT FLANGE
    SIZE & STYLE CONNECTIONS
    PART NO VALVE
    TYPE
    FLOW INLET OUTLET BODY FLANGE
    DESCRIPTION
    ALC-027919 * TER 2 ANGLE 7/8 ODF or 1-1/8 ODM 7/8 ODF or 1-1/8 ODM 9153
    ALC-027918 * TER 2 STRAIGHT-THRU 7/8 ODF or 1-1/8 ODM 7/8 ODF or 1-1/8 ODM 9152
    ALC-027926 * TIR ANGLE 7/8 ODF or 1-1/8 ODM 7/8 ODF or 1-1/8 ODM 9151
    ALC-028849 * TIR STRAIGHT-THRU 7/8 ODF or 1-1/8 ODM 7/8 ODF or 1-1/8 ODM 9150
    ALC-028030 * THR ANGLE 1-1/8 ODM 1-1/8 ODM 9149
    ALC-028032 * THR STRAIGHT-THRU 1-1/8 ODM 1-1/8 ODM 9148
    ALC-065124 TMR 2 ANGLE 1-1/8 ODM 1-1/8 ODF 9149-1
    ALC-065125 TMR 2 STRAIGHT-THRU 1-1/8 ODM 1-1/8 ODM 9148-1
    2 TER- TMR flange includes extended length cap screws.
    STEP 3: SELECT POWER ASSEMBLY
    TCL-TCLE-TJLE-TJR POWER ASSEMBLIES 3
    PART NO REFRIGERANT
    EQUALIZER
    TYPE
    CAP
    TUBE
    LENGTH
    APPLICATION
    TEMP RANGE
    APPLICATION
    MOP 4 (psi)
    POWER ASSEMBLY PART NO
    ALC-052957 * R12 ¼ SAE 10 FT. -20 to +40 NONE XC-726 FC 2B ALC-052957 *
    ALC-035000 * R12 ¼ SAE 10 FT. -50 to +50 55 XC-726 FW55 2B ALC-035000 *
    ALC-056421 * R22 ¼ SAE 10 FT. -20 to +50 NONE XC-726 HC 2B ALC-056421 *
    ALC-024511 * R22 ¼ SAE 10 FT. -50 to +5 35 XC-726 HW35 2B ALC-024511 *
    ALC-025011 * R22 ¼ SAE 10 FT. -50 to +30 65 XC-726 HW65 2B ALC-025011 *
    ALC-059333 * R22 ¼ SAE XC-726 HCA2B ALC-059333 *
    ALC-036750 * R22 ¼ SAE 10 FT. -20 to +50 100 XC-726 HW100 2B ALC-036750 *
    ALC-040569 R22 ¼ SAE 10 FT. -50 to +10 NONE XC-726 HZ 2B ALC-040569
    ALC-057235 * R134a ¼ SAE 10 FT. -20 to +50 NONE XC-726 MC 2B ALC-057235 *
    ALC-057372 R134a ¼ SAE 10 FT. -50 to +50 55 XC-726 MW55 2B ALC-057372
    ALC-063075 R134a ¼ SAE 10 FT. -50 to +10 NONE XC-726 MZ 2B ALC-063075
    ALC-052958 * R502 ¼ SAE 10 FT. -20 to +50 NONE XC-726 RC 2B ALC-052958 *
    ALC-023351 * R502 ¼ SAE 10 FT. -50 to -20 15 XC-726 RW15 2B ALC-023351 *
    ALC-070866 * R502 ¼ SAE 10 FT. -50 to +5 35 XC-726 RW35 2B ALC-070866 *
    ALC-071421 R502 ¼ SAE 10 FT. -50 to +25 65 XC-726 RW65 2B ALC-071421
    ALC-046692 * R502 ¼ SAE 10 FT. -50 to +10 NONE XC-726 RZ 2B ALC-046692 *
    ALC-062303 R404A ¼ SAE 10 FT. -20 to +50 NONE XC-726 SC 2B ALC-062303
    ALC-063127 R404A ¼ SAE 10 FT. -50 to +10 40 XC-726 SW40 2B ALC-063127
    ALC-061692 R404A ¼ SAE 10 FT. -50 to +25 65 XC-726 SW 65 2B ALC-061692
    ALC-063974 R404A ¼ SAE 10 FT. -50 to +10 NONE XC-726 SZ 2B ALC-063974
    (3)Cap screws included with Power Assembly
    (4) Maximum Operating Pressure Limit to prevent motor overload
    THERMOSTATIC EXPANSION VALVES
    34
    Oct 2007
    manchester
    5,639
    45
    Oct 2007
    manchester
    5,639
    45
    http://www.danfoss.com/BusinessAreas...97bb9d760.html danfoss selection page- good luck theres loads of em
    Feb 2012
    libya
    41
    94
    13
    I am looking for Danfoss Expansion valve
    Oct 2007
    manchester
    5,639
    45
    I posted the alco spec for you to identify the rest of the valve,including capacity to help you identify your danfoss equivelent
    Quote Originally Posted by mre212 View Post
    Sep 2003
    ISRAEL
    72
    4,248
    hookster's Avatar
    hookster is offline Veteran Poster I am starting to push the Mods: of RE
    Apr 2007
    Hampshire
    438
    32
    I would recommend fitting an electronic expansion valve as a replacement this you can justify from the energy saving and the multi use should they decide to change the refrigerant.
    The Carel EXE valves http://www.carel.com/carelcom/web/en...p?id_gamma=108
    are the easiest valves to commission in the market and can be set in four easy steps.
    For selection Ev2V24B would suit your application.
    http://www.carel.com/carelcom/web/do.../050001225.pdf
    Feb 2012
    libya
    41
    94
    13
    operating range of ALCO +13....-45°C But i have to cool down the brine to -38°C is that ok?
    hookster's Avatar
    Apr 2007
    Hampshire
    438
    32
    Are you designing a new system or doing a parts replacement? You do not really want to operate in a vacuum with R22 so your TD is getting very close but will suffice just be sure you have selected the correct refrigerant for your requirement. I would have selected R507 or R404a.
    The exe valve I selected will give you a refrigerant duty of 10-14 Kw.
    Feb 2012
    libya
    41
    94
    13
    Quote Originally Posted by install monkey View Post
    Is APPLICATION TEMP RANGE given by °C or°F
    Oct 2007
    manchester
    5,639
    45
    degree's f
    Sep 2012
    India
    77
    13
    Dear mre212
    Instead of finding equivalent of Alco valve you can specify what is the pressure at inlet of valve, what is the evaporation temperature expected and what is the capacity of valve either in Tons or in kW required and what is the temperature of refrigerant before expansion valve and you should be able to select thermostatic expansion valve of danfoss from heir catalog. Let me know your email ID, I will send catalog.
    Sandybapat
    Feb 2012
    libya
    41
    94
    13
    Hello all,and thank you for reply
    my system consist of two bitzer compressors type: S6F-30.2 and one evaporator 40KW (Plate & shell heat exchanger). i use Cacl2 brine as secondary coolant(-38°C) So is ALCO will be OK or not
    ALCO:
    XC726HW100-2B
    MOP code/100
    R22
    Orifice:X9117-B7B
    and what is the difference between this ALCO and Danfoss TEX12 -40°C/+10°C with Orifice 3
    Regards & Thanks
    Sep 2012
    India
    77
    13
    Dear mre112
    Danfoss catalog sent to your email ID.
    Sandybapat
