Results 1 to 24 of 24
    Dec 2005
    Cheshire
    264
    21
    Schrader valve renewal
    Hi.
    Basically I have a discovered a leak after removing the schrader valve cap on the suction side of an old Toshiba R22 split.
    I have a core removal tool and spare cores, just wondering what is the best way to go about repairing the valve, i.e will I have to recover before taking the core out or is there a way around it?
    Thanks in advance.
    Oct 2001
    Nottingham UK
    5,668
    Re: Schrader valve renewal
    You can change the valve with this tool when the system is charged. http://www.hawco.co.uk/refrig/Sectio...Section6_1.htm
    Last item on the page
    rbartlett's Avatar
    rbartlett Guest
    pump it down..
    cheers
    richard
    Dec 2005
    Cheshire
    264
    21
    Quote Originally Posted by frank
    Noticed this tool in HRP and SRW also, was tempted but cannot understand how I would actually attached it onto the leaking valve thread without refrigerant escaping alot/getting burnt!
    Aug 2005
    5,302
    Frank,
    That looks like a very useful tool. I have not seen one of these, but then I have not had to work on any schrader valves for a long, long time.
    It does seem to take all of the fun out of doing a hot change-over on a liquid line though.
    Thanks for the info and heads-up on this tool.
    Dec 2005
    Cheshire
    264
    21
    Quote Originally Posted by rbartlett
    pump it down..
    cheers
    richard
    Thought about that too, havnt got the model number on me, its a 7kw ceiling suspended think about 1997 model, is there a forced cooling mode or will I have to trick it by warming the thermistor as its only about 12 degree c in the room.
    Apologies if there are a lot of questions, as you can prob tell I'm mainly installation!
    Mar 2004
    624
    21
    This is a excellent tool and I use it often,its ideal when charging a pack as the shreader valve restricts the flow.You attach the tool on to the shreader threads then send the extraction rod in and remove the valve this is a sealed chamber,pull the rod back and close the shut off valve on the tool and unscrew rod and valve.
    Hope that makes sense
    Regards Bernard
    Oct 2001
    Nottingham UK
    5,668
    If you are going to pump it down then just hook up the gauges, close the liquid line valve, stick the screwdriver on the contactor and then close the suction valve when the gauge reads 0psig 'nuf said
    11,025
    Quote Originally Posted by Slim R410a
    ..... is there a forced cooling mode .....
    Select Cool mode on the controller when in the Off condition, then press and hold the on/off button until an 'L' appears on the display; you now have about 30 minutes before it reverts to normal or you switch off again.
    You should also have in your PPE kit some heat (cold) resistant gloves shouldn't you ? Ideal for occasions like this.
    Nov 2005
    152
    If you do not want to drop the charge
    Imperial make a tool (PINCH OFF TOOL 105-FF)
    here is the link
    http://www.stridetool.com/tools/hose...etools_01.html
    this tool pinches off your pipe cutting supply of refrigerant to the fan cycle , so you can replace
    without interference to the charge , when replaced it has rerounders of different diameters so you can reround your pipe and let refrigerant flow to the control.
    MANITOWOC recommend using this tool on their
    ice machines as to not interfere with the factory
    charge when changing their fan cycles.
    The primary function of the design engineer is to make things difficult for the fabricator and impossible for the serviceman.
    Jul 2005
    Ireland
    56
    164
    HI Just get yourself one of the schrader extractor tools I've had one for years and its paid for itself many times over.
    T
    Jan 2006
    Port Adelaide
    52
    I see on that link frank you pay 14 pound for a quik connector and 28 for the schrader tool. bargin. In Australia your up for $70.00 and $80-$90 respectivly.
    I've got one of each. Need 2. It was suggested in our training that these items should be compulsory in everyones tool bag to be accredited. Best practice for minimal refrigerant loss.
    Oct 2001
    Nottingham UK
    5,668
    At todays exchange rate the core extract tool £28 would cost $aus 65.58 so a fair saving. Now, taking into account the postage and my handling fee it may not be such a saving for you
    Dec 2005
    Cheshire
    264
    21
    Thanks for all the help.
    I will pump it down using forced cooling mode, if that fails will push in the contactor like said...
    I do have all the ppe etc
    Cheers,
    Oct 2001
    Nottingham UK
    5,668
    Some condensing units do not bring the fan on when you push in the contactor hence the warning sticker on them
    It's best to have the fan running when pumping down to ensure fluid phase change
    Feb 2005
    Aberdeen
    48
    168
    Don't hold contactor in as this is incorrect procedure. I reckon Frank was only joking with you and as you said, you are more used to installation than service you will end up doing more damage to yourself than the air-con unit!
    Be safe at all times
    Jase
    Dec 2005
    Cheshire
    264
    21
    Pumped it down using the forced cooling mode today with no problem at all. (Cheers Brian)
    Dec 2005
    Cheshire
    264
    21
    Yes I have always noticed these stickers on the Mitsubishi R407c fixed speed range.....
    I learn something new everyday
  19. #19
    11,025
    Glad to hear that the problem is resolved.
    BTW if you want forced heating on a heat pump then select HEAT and press/hold the button again and an H will show this time. You don't get and fancy defrosting in this mode it will blow cold air inside!!
  20. #20
    Jan 2006
    Port Adelaide
    52
    Gee Thanks Frank
  21. #21
    Dec 2005
    Cheshire
    264
    21
    Quote Originally Posted by Brian_UK
    Whilst on the subject, what are the differences between Heat 1 and Heat 2 modes on these Toshiba's?
  22. #22
    Jan 2006
    Port Adelaide
    52
    mmmm, yes Brian. Is it possible to purchace stem removers and quik couplers for R410A systems?
  23. #23
    Jan 2006
    Port Adelaide
    52
    Quote Originally Posted by Marc O'Brien
    Mine doesn't do R410A connections?
    Found a R410a quik couler manufactured by REFCO. Part number V-3541015. I was told they don't exist. And I have seen both schader core remover and coupler. I'll get back with a part number on the former
  24. #24
    Dec 2005
    Cheshire
    264
    21
    Ive had R410a quick couplers for ages, SRW do a set with a straight one and a 90 deg. one! Never had a cold burn since
  1. Fitting an expansion valve question
    By Larry2 in forum Air Conditioning
    Last Post: 08-04-2008, 04:17 PM
  2. Scotsman commercial H2O inlet valve
    By fullcourt in forum Trouble Shooting
    Last Post: 25-04-2006, 11:41 PM
  3. Need a correctly sized valve
    By Abe in forum Commercial
    Last Post: 26-10-2005, 08:42 PM
  4. Replies: 5
    Last Post: 16-10-2002, 12:38 AM
  5. Valve "Hunting"
    By Abe in forum Trouble Shooting
    Last Post: 21-01-2002, 12:29 AM
