Results 1 to 9 of 9
Thread: Fan Motor
    Aug 2011
    Uk
    48
    Fan Motor
    Hi all,
    and a very Merry Christmas.
    I've got to change a fan motor on a Mitsibishi PKA-RP71FAL. Never changed or seen one before. Can this job be done with the wall mount on the wall or does pumping down? Also, are there any special tools I need for the job?
    Thanks for your time.
    Oct 2007
    manchester
    5,639
    45
    Re: Fan Motor
    yep- no degassing- just strip the bugger to just a coil and backplate, allen key for the grub screw on the impellor, I recommend replacing the end bearing too-good luck
    Aug 2011
    Uk
    48
    Re: Fan Motor
    Thanks install monkey,
    I've only been given a motor so will have to wait if its still making a noise.
    Oct 2007
    manchester
    5,639
    45
    Re: Fan Motor
    before you go on site, check the motor isn't damaged, I drove 180 mile to oxford, signed in on site, opened the box to find the plastic body cracked!!
    Somerset
    69
    4,698
    Re: Fan Motor
    You have a good point there IM.
    Thankfully not to often.
    But I have known issues with spares straight from the box.
    Sometimes the wrong part entirely!
    Your onto a winner when you actually have the part in your hand.
    When they are sent direct to site, Well!
    Aug 2011
    Uk
    48
    Re: Fan Motor
    I'll check.
    Cheers.
    Oct 2007
    manchester
    5,639
    45
    Re: Fan Motor
    check ur e mail too
    Aug 2011
    Uk
    48
    Re: Fan Motor
    Thanks Install Monkey.
    I needed that!
    Merry Christmas
    Aug 2011
    Uk
    48
    Re: Fan Motor
    Smooth motor replacement.
