HELLO
CAN ANYONE WITH EXPERIENCE PLEASE HELP;
SAMSUNG RSG5DURS FRIDGE FREEZER TWO AND HALF YEARS OLD, FAULT = UPON START UP FREEZER GETS TO SET POINT WITHIN AN HOUR OR TWO AND THEN THE TEMP RISES TO ABOUT -4 FLUCTUATING AT THAT TEMP, FRIDGE OK HAVE USED DATA LOGGER TO CHECK, ALL THE TIME THE DISPLAY SHOWS -20 THE SET TEMP, FRDGE +3 IS OK, IF I RESTART THE CABINET IT DOES THE SAME EVERYTIME. i HAVE CHECKED THE OBVIOUS,BOTH DEFROST HEATERS ,THERMAL FUSES, CHANGED ALL FOUR PROBES AND BOTH PCB PANELS AND AMBIENT SENSOR, CHECKED R600 GAS CHARGE, NO FAULT APPEARS UPON SELF DIAGNOSTICSAND COMPRESSOR IS RUNNING NICE AND WARM BOTH EVAPS FULLY FLOADED WHEN ASKED FOR.
THIS IS THE FIRST TIME I HAVE BEEN BEATEN AND HAD TO ASK FOR HELP, IT HAS BECOME A CHALLENGE.
THANKS BAZZA.
