12-12-2012, 10:18 PM #1
Controller for Carrier 4 pipe fan coil 42EM
[edit: I'm a dummy, can't even get the model right, it's a 42EM]
Does anyone know which model remote controller goes with this 42EM carrier fan coil unit.
The unit has an NTC communicating controller attached but I can't identify the remote controller required to match it.
I have found details on the CRC2 and Aquasmart controls but they don't mention this fan coil model.
Any help welcomed.Last edited by Brian_UK; 13-12-2012 at 10:29 PM. Reason: Used wrong model code, should be 42EM not 42EW
12-12-2012, 10:36 PM #2
Re: Controller for Carrier 4 pipe fan coil 42EW
The Aqualia may be provided with a 3-speed Carrier electronic
wall thermostat.
With this option each Aqualia can be equipped with an “on/off”
type water control valve and flexible water pipes to simplify
the connection of units to the primary hot and/or chilled water.
This electronic thermostat option also includes a male-female
quick connect terminal block for connecting the different wires
from the fan motor, valve actuators, the electric heater and the
heating/cooling changeover switch for Aqualia units equipped
with a single “heating or cooling” coil.
12-12-2012, 10:42 PM #3
12-12-2012, 11:40 PM #4
last resort dave.stronghill@carrier.utc.com
13-12-2012, 10:34 PM #5
Re: Controller for Carrier 4 pipe fan coil 42EM
Thanks for the info IM, sadly the controller used for the 42EL is different, as well as me putting up the wrong model myself, it's a 42EM not EW; doh!
Emailed Carrier today with the full model number as well as the control pack details that comes with the unit and the first reply was - "Can you send me a picture?". Doesn't inspire too much confidence.Brian - Newton Abbot, Devon, UK
