12-12-2012, 09:13 AM #1
WTK plate heat exchanger as a condenser
Anyone has expirence with WTK plate heat exchanger (P7-20)as a condenser
Is hot gas from compressor should be connected to the top or bottom?
thank you
12-12-2012, 10:33 PM #2
Re: WTK plate heat exchanger as a condenser
Pipe connections depend on the model number reference, see here...
http://www.wtk.it/en/prod_piastre_monocircuito.aspBrian - Newton Abbot, Devon, UK
13-12-2012, 07:12 AM #3
Thanks Brian UK belive me but there is no information about it
and it says from the bottom but I think its incorrect
14-12-2012, 03:51 PM #4
Discharge allwyas on top so that the condensed liquid can flow down.
