Results 1 to 2 of 2
    Dec 2012
    indonesia
    1
    R407C MIX with R404A
    is there any body knows what will be happened if mixing R40C with R404A ?
    its Can Be mixed in the system or will be have a big Problem?
    Sep 2003
    ISRAEL
    72
    4,248
    Re: R407C MIX with R404A
    I don't know what will happened if you ix those refrigerants, most probably it will work less efficient or with funny pressures.
    Just make sure there is no R-40 in your mixture.
