Thread: Mitsi electric vrf bc box noisey
08-12-2012, 12:38 PM #1
Hi all,
I have been working on a site that has had 4 mitsi electric vrf systems recently installed, Friday evening on my last walk around the building, I can hear a high pitched noise coming from the bc boxes from different systems.
You can hear the gas moving around, coming from the bc box, then there's a high pitched noise for a couple of minutes, which disappears then returns.
Can anybody have a guess at the cause, or has anybody else come across the same thing.
Cheers in advance, Craig
16-02-2013, 08:10 PM #2
Re: Mitsi electric vrf bc box noisey
Faulty valve in box !!!
17-02-2013, 11:35 AM #3
Defrost or SV1 bypass opening to control suction pressure in outdoor
