Results 1 to 14 of 14
Thread: Freezing tunnel evaporators
13-01-2006, 09:24 AM #1
Hi there,
Can anyone introduce an evaporator manufacturing company for freezing tunnels (-35°C room) with R22?
I need the required coil surface area with the capacity.
Appreciate any comment.
Even Einstein Asked Questions
15-01-2006, 07:39 PM #2
Re: Freezing tunnel evaporators
What capacity of coil are you looking for? Is it a direct expansion or pumped liquid over-feed application?
Aerofreeze and Krack are a couple of manufacturers that build both.
16-01-2006, 12:54 PM #3
Originally Posted by D. Sergius
Thanks for the reply. I have checked the companies you mentioned but there is no catalogue available!!
I need a blast freezer evap. for R22 DX. The capacity is 20kW @ -40°C TD=5°C.
Cheers.Even Einstein Asked Questions
26-01-2006, 12:01 PM #4
pls help me
Hello
who can help me with some documentation to make a refrigeration tunel/fast refrigeration, or a software(or just the formulas) for the calculation of refrigeration power
TNX
26-01-2006, 12:18 PM #5
hi lana
this is a good and famous company in industrial refrigeration
www.grasso-global.com
they do ice skatting feild in dubai (3 football stadum large)
thanks
26-01-2006, 12:47 PM #6
i have one freezing tunnel with 12x 5.5 x 3.5 m (Lxlxh).
I have 3000 kg meat(pork/chicken/beef), polyuretan 150 mm insulation, i don't know how long is the procces.
What reffrigered power is required? i need -40°C in the tunnel , R404 or R134
26-01-2006, 12:52 PM #7
salut rrahan
give me your e-mail adress..maybe i can help you...and welcome to ref-eng"do not follow where the path may lead. go instead where there is no path and leave a trail" R.W.Emerson
26-01-2006, 06:25 PM #8
Originally Posted by rrahan
3.000 kg doesn't say anything?
Available time for freezing? This is the most important factor for your project (will take at least half a day)
Entering temperature and desired temperature after freezing?
Cutted meat or carcasses?
In boxes or open in trolleys or on a belt?
If boxes, type of box?
Feed through tunnel (FIFO)?
-40°C with R134a
-40°C is evepaorting at -46°C to -48°C
For me 150 mm PU is not enough for -40°C inside.
Estimated capacity (I'm taking water, counts easier) of (3000 x 10 x 1) + (3000 x 85) + (3000 x 20 x 1)/10hours or 37 kW + 10 kw for the fans = +/- 45 to 50 kW or 50 HP.
Preferable with a pack.
Don't forget also that a freezing tunnel is not such an easy project as it seems on the first sight, especially if you don't have enough experience with it.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
Originally Posted by lana
dont know if you found what you were looking for, but anyways, Fincoil has a wide range of evaporators, we use them from time to time and They are pretty good quality.
http://www.fincoil.fi/products.html
-Cheers
Tycho
28-01-2006, 08:33 PM #10
Lana,
Please email me directly @ msanchez@ams-pmt.com
I will forward your request to Krack / Evapco/ Frick-Imeco and Colmac.
These are all Industrial Evaporator manufacturers.
I deal with these people daily in th US.
They should all have websites that you can visit.
Many industrial coils are custom designed.
I am involved with IIAR / ASHRAE & RETA
Mark
31-01-2006, 01:13 AM #11
Hello, you can visit
http://www.guentner.de/
they also have a GPC calculator to download. Their products are very good, I'm working with them for a long time. From calculator you can choose DX evaporator and condenser.
From http://www.bitzer.de you can dowload software for compresor. I do believe that you are going to make a charging freezing tunnel (cold room) what is much easier than to make a good continuous freezing tunnel.
Anyhow, this is not a simple project and if you don't have a good experience ....do not start.
Best regards!
Josip
31-01-2006, 11:28 AM #12
Try with ECO and Alfa laval!
Renato
31-01-2006, 04:46 PM #13
All fine but what capacity he needs now?
31-01-2006, 06:24 PM #14
RRAHAN
Salut
What cooling time do you need?
I will try to help you
1 Tev 2 Evaporators
By Renato RR in forum Technical DiscussionsReplies: 14Last Post: 18-11-2009, 02:58 PM -
Quick freezing of fresh products
By maxim971 in forum Technical SpeculationsReplies: 12Last Post: 18-09-2009, 11:06 PM -
Freezing problem
By MajinDave in forum Trouble ShootingReplies: 10Last Post: 15-07-2006, 12:01 AM -
Shrimps Brine Freezing
By refac-45 in forum IndustrialReplies: 3Last Post: 12-05-2006, 08:24 PM -
Problem with three evaporators and TEVs
By lana in forum Trouble ShootingReplies: 16Last Post: 13-01-2006, 09:52 AM
