Results 1 to 17 of 17
05-12-2012, 07:59 AM #1
Fujitsu split system emanating fishy odour
I have a 2yo Fujitsu Split System and the indoor unit (ASTA18LCC) started delivering fishy smelling air yesterday!!! Been fine till now. (We had a stinking hot day 3 days ago and the system was on all day, but we've done that before without any issues).
Question: How can I get at the drain pipe to run a wire down it? Would anyone pls have diagrams on what to do for this model? The drain pipe according to the manual is at the back on the RHS, but I cannot see how to get at it.
Thx very much,
JB
05-12-2012, 07:14 PM #2
Re: Fujitsu split system emanating fishy odour
This is a of the blind leading the blind, but as no one else ha fielded this; here goes..
Normally ONE SHOT CONDENSATE DRAIN CLEANER will do the trick. Be careful with the stuff it burns your skin like hell.
Also, fishy smell is normally associated with electrical burning, So be on the look out for this too.
Hope this helps (a bit)
Martin
05-12-2012, 07:53 PM #3
05-12-2012, 10:24 PM #4
Carefully pour the cleaning fluid onto the face of the evaporator coil near the bottom of the coil and at the LHS. This will flow into the drain tray which runs along the bottom of the coil towards the drain outlet at the RHS.
05-12-2012, 10:39 PM #5
^^^^^^What he said, but wear gloves and goggle and long sleeves, specially if your first time doing it, the bottles come with a special spout.
05-12-2012, 10:46 PM #6
ensure the drip tray is empty before pouring in, could also be the coil stinking- usually smells of cat piss- last resort smelly jellys
05-12-2012, 11:07 PM #7
05-12-2012, 11:28 PM #8
Spray some Condenside spray on the coil and keep the coil wet for ten minutes then rinse.
If this don't work check for fish in unit...Mostly found in Oxfordshire, UK :)
08-12-2012, 09:12 AM #9
25-12-2012, 10:40 PM #10
Sorry for the delay in getting back....
I have attatched a photo of the front. Am I supposed to just pour the liquid over these fins? I can't see anywhere else to pour/spray it.
Thx,
John Bradshaw
25-12-2012, 10:44 PM #11
25-12-2012, 10:45 PM #12
To be brutally honest with you, looking at that picture your unit need a professional deep clean.
Sorry.
25-12-2012, 11:16 PM #13
25-12-2012, 11:23 PM #14
25-12-2012, 11:38 PM #15
Thx very much...Shall try this after the boxing day lunch!!
JB
26-12-2012, 06:32 AM #16
you could always call someone in to clean it properly with the right cleaning solution!
26-12-2012, 11:39 AM #17
