Results 1 to 8 of 8
29-11-2012, 05:55 PM #1
tecumseh single phase compressor wiring
hi guys im working on a small 3kw water chiller and the compressor is being changed. The original comp had only 1 run capacitor and thermal oload.But the new comp has start cap and run cap and a relay supplied with it. On the comp it has everthing same details but on the box it came in says CSR.Can it be wired same as old one with only 1run capacitor or do i need to wire it in with full set of electrics it came in with.Thankyou
29-11-2012, 07:16 PM #2
Re: tecumseh single phase compressor wiring
wire as a csr comp, just l,n,e to the box, make sure the box is mounted securely and upright, you will wire a pressure switch accross L and 1- if no press switch the fit a link,also hook ur cond fan up to 1,n e job done
29-11-2012, 08:40 PM #3
Hey ghaz, its all here:
http://www.embraco.com/desktopmodule...vos/mp01eg.pdf
29-11-2012, 09:03 PM #4
Thankyou guys. I couldnt understand why 1 comp runs on run cap connected to the start winding and new machine comed in with different electrics set up
29-11-2012, 09:06 PM #5
1 cap compressor- psc type high start torque, you'll know for next time
29-11-2012, 09:31 PM #6
Thankyou for info friend
30-11-2012, 08:36 AM #7
30-11-2012, 05:36 PM #8
Hi rob i changed all new electrics
