Thread: Hauser
29-11-2012, 01:35 PM #1
Hauser
Does anyone have pdf's on the following controllers installed on a Hauser HT pack
WURM SYSTEME DCC-XP V3.3
WURM SYSTEME HZE 001
Thanks in advance
James
29-11-2012, 08:52 PM #2
Re: Hauser
HAUSER GmbH UK – John Thompson
The Manor, Tur Langton
Leicestershire LE8 OPJ – United Kingdom
Tel.: +44-1858-545-300 - Fax: +44-1858-545-799
thompson@hauser.com – www.hauser.com or did you mean- PDF] Surfscan 5500 Manual
mfc.engr.arizona.edu/documents/Surfscan/Surfscan5500Manual.pdf
You +1'd this publicly. Undo
File Format: PDF/Adobe Acrobat - Quick View
This system contains a helium-neon laser rated for 5 milliwatts with x minimum ... LASER item. wurm oren Laser agaülnsāsen .... .155 pm .256 .002 .003 - .020 .001 .005 .... and Haze Maps with X-Y particle addressing and 8-bit-size resolution.
01-12-2012, 01:08 PM #3
Re: Hauser
Not that one IM, Hauser seem some what reluctant to offer technical support
Cheers though
01-12-2012, 05:11 PM #4
Re: Hauser
http://www.hauser.com/partner-leistu...gen-34/lang-en found the right company- but no sign of any manuals
01-12-2012, 05:55 PM #5
Re: Hauser
Manuals are not freely available, is it a specific problem you are having or do you need to reprogram?
alMostly found in the southern part of this green and pleasant land.
01-12-2012, 06:14 PM #6
Re: Hauser
I had an alarm on a pack the other day and as usual no info on the controllers, i got it sorted in the end turned out to be a defrost probe,
