Thread: Daicool
11-01-2006, 06:22 PM #1
Daikool
Anyone have any fault codes for these units?
I've been persueded to help out a "friend" on Friday and complete the installation of a heat pump unit in someone's conservatory and I'm trying to go tooled up ready for the inevitable
Must admit I've never heard of them but so far it don't look good. The condensing unit has been installed on brackets tight into a corner wall so there is no access to the electrical cover or room to get the spanners in to tighten the flares - I've told him it's got to be moved and he say's - why?
Then he shows me where he has knocked out a brick so that I can thread the pipes through the wall cavity to the indoor unit
I'm not looking forward to Friday.
I'll take the cameraLast edited by frank; 11-01-2006 at 09:24 PM.
11-01-2006, 06:33 PM #2
Re: Daicool
http://www.daikool.co.uk/.
i think they are re-badged Haier gping of the model codes
cheers
eggs.
13-01-2006, 10:11 PM #3
Re: Daicool
these look very similar to the stuff we sell and the same model numbers.
here are the faults codes if you need them.
E1: Indoor air sensor abnormal
E2: Outdoor air sensor abnornal (the thin black cable between indoor and outdoor)
E3: Indoor exchanger sensor abnormal
E4: Outdoor heat exchanger sensor abnormal
regards
Paul
14-01-2006, 12:17 PM #4
Re: Daicool
Thanks lads.
Install went better than I expected and the unit ran first time. Fairly quiet in operation - you could say I was impressed
