Anyone else find aquamat's build up with that bacterial jelly within 4 weeks? Blocking the tray and outlet hose causing pump failures.
I've started using in-cistern bleach blocks (normally used for toilet flushing systems)bin the aquamat trays.
It's 6 weeks on and working really well. Only trouble is the block has now dissolved and needs replacing.
Anybody know of another type of block that would do the same job but dissolve slower?
