Results 1 to 2 of 2
Thread: manitwok problem model sd0852a
28-11-2012, 10:40 AM #1
hi there just got into the field and trying to gain experience and do stuff right!
I overcharged a manitwok ice machine and something blew off for a couple seconds, now its shows a s2 fault light , the water pump and compressor both come on for a few second then everything shuts down and the s2 light blinks, repeatedly. yes i should have weighed it in. i thought i could do it a by amp draw a bit.
whats happened? how do i get back to normal cycling?
28-11-2012, 07:00 PM #2
Re: manitwok problem model sd0852a
Recover, pressure and leak test, replace drier. WEIGH the charge in, it's the only way to be sure, then check how long it takes to make a batch. Manitowoc used to do a technicians service book, covers all models.
alMostly found in the southern part of this green and pleasant land.
