Thread: r22 city multi problem
10-01-2006, 06:05 PM #1
Hello chaps just wondering if anyones cams across this problem before.
I had a service call on the old r22 city multi today, 2 units in the chief executives office not heating.Anyway found the r/c set wrong ran on 24 heating worked fine. Decided to check all other units on heating, found 2 out of 6 wouldnt heat at all yet they will cool staifactory.Im sure the system is ok for gas because the pressures are norm and the furthest units are performing.is it worth swapping the solenoids for heating in the bc box with the cooling ones.Even tried re calibrting all the indoor exp valves.
10-01-2006, 06:22 PM #2
Re: r22 city multi problem
may be worth checking the gas charge have heared of this problem before from another engineer they had exactly the same symptoms running fine in cooling but not in heating and it turned out to be short of gas , not sure why this occurs may be worth a check though
hope this helpsNoah had to leave the dinosaurs behind as they would've sunk the boat.
10-01-2006, 07:46 PM #3
Suction and discharge pressures won't tell you that much on a VRF. Take the front cover of the outdoor, and on the bottom right unscrew the metal cover, check for a fault code if there is one. Check EEVs for units and make sure the motors are opening them properly. If you think there is a refrigerant problem, then you will have to weigh it out to decide if the problem lies there.
a problem shared is a problem halved
11-01-2006, 06:27 PM #4
Hi there chaps, just to let you know i sorted the problem.it was a fulty coil (solenoid b) swapped it with one on a port not bieng used.
The model was pury-250yma b.
Thanx for your ideas anyway guys
Need input on City Multi
By TDfromNY in forum Air ConditioningReplies: 4Last Post: 09-06-2006, 03:31 AM -
mitsi city multi r407c
By mr slim in forum Air ConditioningReplies: 6Last Post: 06-03-2006, 10:54 PM -
Mitsi City Multi Compressor Death
By aeb200 in forum Air ConditioningReplies: 4Last Post: 16-11-2005, 09:10 AM -
Mitsubishi city multi
By techni in forum Air ConditioningReplies: 2Last Post: 04-07-2005, 05:37 PM -
city multi
By techni in forum Air ConditioningReplies: 1Last Post: 30-06-2002, 11:02 AM
