Results 1 to 17 of 17
    Scotland
    312
    11
    Angry Evaporator hell: Tube in tube leaking
    Dear Friends
    I've been working on a TES water-water heat pump manufactured by TES model 25-1 R407 2kg.
    The current problem is that the evaporator is tube in tube and has split, causing water to leak everywhere. It's completely inaccessible without disconnecting everything and lifting the unit.
    I think it's split because of problems with the source water pump, no flow and therefore low pressure, causing the water to freeze.
    I think there's every chance the fridge pipes inside it will have been damaged as well, and the whole evaporator will have to be replaced.
    I had it working for a few days but it's gone off again, the source water is running OK so I suspect gas leak now.
    TES have gone bust.
    Does anyone know where I can buy a suitable replacement or have any advice?
    May 2008
    Canada
    30
    Re: Evaporator hell: Tube in tube leaking
    Hi, I have used Wilson Titanium for custom water chiller barrels. He makes a very efficient, industrial duty pvc shell/titanium tube evaporator. And can build whatever size you need. I know he has shipped all over the world, but is located in Halifax, Nova Scotia, Canada. His web site is http://www.titaniumproducts.ns.ca/
    He also makes auto-revsersible water-to-water heat pumps.
    Dec 2010
    devon
    777
    the guys that work for tes is now called aqua water chillers in exeter give him a ring they said they can get parts ok ta charlie
    Scotland
    312
    11
    Very helpful, thanks.
    Scotland
    312
    11
    Do you have any contact details for Aqua Water Chillers in Exeter Charlie, I cant find anything on line!
    Dec 2010
    devon
    777
    its in the office will get
    Sep 2003
    ISRAEL
    66
    4,118
    38
    if you know the capacity, you can check on any coaxial evaporator manufacturer.
    any flow control?
    is it Chinese?
    Scotland
    312
    11
    No, there's no flow control, the manufacturer is British, I not sure about the heat exchanger, I think they just constructed it with parts from all over the place, could be Chinese I guess. I'm hoping that coaxial evaporators come in standard sizes.
    Scotland
    312
    11
    The only flow control is the source water pump which is fixed speed, its about 2 or 3 bar.
    Scotland
    312
    11
    It needs a minimum of 30L / min which it gets no problem
    Aug 2007
    Sydney
    45
    1,093
    Hi Contactor
    Just an old school thought is you could build a tube in tube heat exchanger simply, if you had a rough idea of what the dimensions are. Copper is simple with a little heat and not too sharp on the radius. Stainless you will need to pack with dried sand and heat to cheery red. I have made both with minimal time and tools.
    Dec 2010
    devon
    777
    spoke to aqua today they said give there head office a call as they have some contacts and listing of tes kit on 01329840503 there rep was with tes they helped me the other day
    Scotland
    312
    11
    Thanks Charlie
    Tesla - Will give it a go if all else fails
    Dec 2004
    U.K
    49
    517
    15
    Good Luck, I have a customer with some TES kit and they apparently lost a load of info a few years ago when they moved. But the administrators did put him in touch with a guy that used to work for them who knows the kit I am sure I can get his number if you need it.
    Hopefully you will be able to find what you need.
    Best regards,
    djbe.
    Oct 2003
    56
    5,519
    28
    Why not place a new PHE beside/outside the unit and leave the defective one in place? Small and cheap.
    Scotland
    312
    11
    I'm not sure what a PHE is Peter, is it a Plate Heat Exchanger? Its a tube in tube heat exchanger that's leaking..........?
    Aug 2008
    Auckland
    49
    247
    14
    Quote Originally Posted by Contactor View Post
    Correct, PHE is just that....a Plate Heat Exchanger. It doesn't matter that the original is tube in tube, both do the same thing, just in a different way. Once you know the specifications of the original, easy to match a PHE tot replace the Tube in Tube.
Tags for this Thread
