Results 1 to 14 of 14
    Nov 2012
    israel
    1
    Cool What is the smallest and lightes compressor out there 1/4-1/5 for use with R134a
    Hi guys Im looking for the smallest compressor I could find for an aplication where i have very little space. I need between 1/4 to 1/5 HP and must use R134a. And if it couldnt get whorse I need it in 110vac 220vac and 12-24vdc
    Thanks,Dave
    Sep 2003
    ISRAEL
    72
    4,248
    Re: What is the smallest and lightes compressor out there 1/4-1/5 for use with R134a
    Check with Embraco.
    Do you mean that the compressor will run on on all these different voltages? Cause if so, you better stop searching, there is no compressor (to my best knowledge) that runs on ac and dc.
    Apr 2008
    LUTON
    Quote Originally Posted by davhaz View Post
    Thanks,Dave
    there is a hell of a lot of difference between 1/5th & 1/4 compressors and what they are capable of. What are you going to use it in ? CF ?. If its space then why dont you use R600A which is more efficient and quieter.
    Bryan
    3,856
    Danfoss make some small DC comps, the could run direct (via their control box) or from the mains via a converter to feed their controller.
    Start with the cooling duty you require, then look to see what compressors are suitable rather than starting with the compressor.
    Jul 2009
    South Africa
    79
    195
    Embraco made some rotary compressors around 1/4 hp that were only available through whirlpool. They were smaller than a normal compressors of the same horse power. They were used on large domestic fridge freezers with the doors side by side and they were available in 110v and 230v but I'm not sure about DC
    Mar 2010
    usa
    120
    This may work for your application.http://www.aspencompressor.com/
    Apr 2008
    LUTON
    Quote Originally Posted by THE DUDE View Post
    These compressors require a particular PCB controller also so it may make it uneconomical. The embraco ones are also inverter compressors.
    dependent on the capacity of what you either want to cool or freeze depends on what size you need. Why only R134a as its a crap refrigerant.
    Bryan
    3,856
    Quote Originally Posted by R600A View Post
    Bryan
    Why is R134a a crap refrigerant?
    11,025
    I reckon that these little babies are the smallest that I know of.....
    http://www.appliancedesign.com/ext/r..._9-28-2011.pdf
    Mar 2010
    usa
    120
    Im not sure either...I didnt know S#*t needed to be Refrigerated
    Aug 2009
    New Zealand
    2,554
    26
    Time to look at TEC!!!!!!!
    Jul 2012
    Australia
    57
    61
    12
    I have just been looking at 1/12th hp on line think you can get 1/16th, what do you want to do?
    Sep 2010
    Aarhus
    71
    1
    Hi Dave, SECOP can do it, best regards Claus Jensen - Danfoss Technical Support Refrigeration, need help? My mail is cbj@danfoss.com
    I attach SECOP data scheet selector.
    http://www.secop.com/data-sheet-sele...tml?fontsize=1
    Apr 2013
    great got agood concept and idea i will consider it in future thankyou for such post
