Results 1 to 50 of 136
Thread: Lg Air con
Threaded View
28-04-2006, 08:04 PM #11
Re: Lg Air con
M*rc
IE a Daikin is quite a simplistic installation which needs little or no brain power to install or even actual commission.
Meowww. carefull, Frank may be listening.
It seems once again that Fujitsu is clearly far better than anything else. it's cheapish, and you can install and walk away leaving the end user to power up and chill out.Takes a licking, keeps on ticking.
