    Nov 2012
    uk
    1
    beko frost free fridge freezer not working (not cold enough) - help
    Have had the fridge freezer over 2 years and moved recently. Its in an internal garage. Its working but not cooling enough. The fan doesn't work no matter what the thermostat is set to. Have slaved a new fan in but still didn't work. Replaced the thermo block in the freezer, still no fan. Defrosted it for 3 days.
    Any ideas what's wrong and is it worth fixing or should i scrap it?
    May 2012
    59
    1,528
    36
    Re: beko frost free fridge freezer not working (not cold enough) - help
    I don't know what the problem is but I will ask a very obvious question.
    What is the temperature inside the garage?
    Some fridge freezers will not work if the ambient is is below
    about 6 or 7 deg c.
    Other than that I would say it is a controller issue.
    Rob
    Apr 2008
    LUTON
    about 6 or 7 deg c.
    Majority of domestic fridges/freezers require a minimum of +13oc and some even +18oc.
    At a guess your unit maybe stuck on defrost,At the rear next to the compressor ther is a small bos with a small round slot in it. turn the slot clockwise slightly,If it starts then you have either a defrost timer fault or a defrost circuit problem.
    Bryan
    Somerset
    69
    4,706
    Good advice and welcome to the forum R600 / Bryan.
    Judging by your handle I guess you are into domestics?
    If so your advice will be most welcome!
    Apr 2008
    LUTON
    [QUOTE]judging by your handle I guess you are into domestics?
    If so your advice will be most welcome![/QUOTE]
    Yes.. We specialist is R600a And domestic refrigeration.
    Bryan
Tags for this Thread
