Thread: coolpack issue
    Nov 2012
    netherlands
    37
    1
    coolpack issue
    coolpack seems to have some kind of problem lately.
    when the most simple of curves is created it automatically has a lot of undercooling and some underheating, while i'm only specifiing 40 degrees celcius as condenser temperature, the rest is stock settings.
    does anyone have the same issue? of a solution?
    i've tried multiple PC's en win7 as well as winxp, all the same...
    i hope the picture works so you have an idea what i'm experiencing.
    tnx in advance
    Split Croatia
    57
    6,151
    36
    Re: coolpack issue
    No, picture is not clear and we should see what values you are entered.
    Jun 2008
    Finland
    45
    34
    Re: coolpack issue
    If that picture is correct you have entered evaporating temp to coolpack.
    Try to change it to condensing and it is correct.
