Thread: York Compressor - 25% Capacity
08-01-2006, 01:49 AM #1
Having this run at minimum capacity without loading, should we expect oil capacity problems?
08-01-2006, 10:07 AM #2
Re: York Compressor - 25% Capacity
ok so it could be expected that each time cylinder heads are opened, one could loose a few litres of oil.
08-01-2006, 01:30 PM #3
Not to forget the oil that remains in the discharge manifold..:-)
08-01-2006, 01:36 PM #4
Precisely yes it will loose some oil, still remain in the system due to unloader valve closed.
rudimustardseed:) :) :)
York Screw Chiller How low will it go?????
By bruceboldy in forum Industrial CompressorsReplies: 11Last Post: 10-08-2007, 10:29 PM -
R-407C and Coil Capacity
By glabah in forum RefrigerantsReplies: 5Last Post: 03-06-2006, 11:36 AM -
Capacity achievement
By Hemant Anand in forum IndustrialReplies: 8Last Post: 18-12-2005, 01:18 AM -
New Capacity Control Solution
By embrown in forum New TechnologiesReplies: 19Last Post: 30-12-2003, 01:33 PM -
TEV capacity related to pressure drop
By DaBit in forum CPU OverclockersReplies: 8Last Post: 06-12-2002, 05:11 PM
