    Feb 2012
    7
    Bosch Fridge Freezer - Broken compressor filler pipe (I broke it)
    I helped my sister move at the weekend and managed to damage her Fridge Freezer.
    After moving I noticed a small oil patch on the floor (about half a teaspoonful max). I could not work out where the oil had come and assumed it was OK and plugged it in. It seemed to work fine and I unplugged to move it to its final location.
    When unplugged I could hear a slight hissing which was coming from the short stub pipe (filler?) on the compressor, on close inspection I could see the pipe was cracked. I tried to halt the leak by crimping the pipe and by using some Araldite but could not stop it.
    I assume by now that all the gas has gone.
    So :
    1) Can this be repaired?
    2) How much would it cost to repair the pipe and re-gas the FF?
    3) Is this something that an be done as a DIY job?
    Jul 2006
    norfolk
    737
    Re: Bosch Fridge Freezer - Broken compressor filler pipe (I broke it)
    email us we can help airkool@hotmail.co.uk
    check out my website www.airkooldomestics.co.uk
    Feb 2012
    7
    Hi Tonto33, email sent, your local to me as well !!
