Results 1 to 2 of 2
    3,356
    Mycom wbhe compressor speed
    Is there any Mycom guys out there that can advise on minimum speed for a WBHE recip compressor.
    The WB series could go down to 650 rpm with low speed oil pump.
    Is there any reason why a WBHE with low speed oil pump can't do the same?
    I think they use the same oil pump!
    Auckland
    74
    3,357
    37
    Re: Mycom wbhe compressor speed
    Hi Ranger1,
    that is a big beast of a compressor going slow, mycom spec min speed at 800 RPM. Perhaps a WA could fit into spec. Cannot see why a low speed WB pump would not fit in alright. Oil pressure diff is the criteria have ago and see what happens, the bypass reg should manage flow.
    magoo
