Results 1 to 12 of 12
    Jan 2006
    Ontario
    9
    New person says hi and looks for p/h chart for R-12
    I am new here
    I am not use to the site yet and I was searching for a "pressure/ enthalpy chart for refrigerant 12
    I found the heading in the site which I have listed below, but I was unable to open it.
    Links and Downloads Database
    Pressure-Enthalpy Chart
    My request is if any body can lead me to a P/h chart for refrigerant 12
    My instructor gave us one which is barely readable so I got one from the net BUT, the
    KJ/Kg is way off base.
    I do not understand and my instructor can not say why.
    I am in 3rd year marine engineering and doing air conditioning in my 3rd thermodynamics.
    The chart which is barely legible, that our instructor handed out, works with our calculations from the text book (Basic Engineering Thermodynamics by Rayner Joel) so we will be using it to prepare for our 1st class Marine Engineering test after graduation.
    I would like to find a chart that I can see clearly and that has the proper enthalpy scale.
    Thank you in advance
    I hope to add to the forum on a regular basis.
    Aug 2005
    5,302
    Re: New person says hi and looks for p/h chart for R-12
    Welcome to the forum,
    You said the enthalpies were not correct on one of the charts. My question is, how are they not correct? Do they not compare favorably to another chart?
    One thing you should be aware of on these charts is that they can be different. Sometimes the charts (and tables for that matter) can be based on different reference temperatures.
    In some charts, the zero enthalpy is based on Zero, in others the reference temperature is -40. If you compare one enthalpy from one chart to another chart, it is possible that the enthalpies for the same point will be different. Same for some refrigerant tables.
    Whenever you are doing mass flow calculations or other procedures using the refrigerant PH chart or tables, you need to make sure that the Zero enthalpy reference is the same.
    DO NOT use different charts or tables as they will lead you to make incorrect calculations.
    I suspect this is the problem you are experiencing.
    As to the problem of the link not working, I will have to check this. It worked when I posted it, but for some reason is not, now.
    Oct 2001
    Nottingham UK
    5,668
    http://www.et.web.mek.dtu.dk/Coolpack/UK/download.html
    Download COOLPACK and within the program go to Refrigeration Utilities.
    You can print off P/T charts for any refrigerant
    Oct 2001
    Nottingham UK
    5,668
    OOps sorry
    Just noticed at the bottom of the page you can download Refig Utilities seperately
    Jan 2006
    Ontario
    9
    Thank you everyone
    Jan 2006
    romania
    59
    I need the Molier diagram (T-s) for water. Please help me
    Aug 2005
    5,302
    Hi marianstancu,
    Here is a copy of the information you requested. I hope this is useful.
    Best Regards,
    US Iceman
    Attached Files Attached Files
    Mar 2005
    638
    Something I remember from days gone bye...especially on R-12, different manufacturers of the refrigerant used a different base line for the R-12 and had different enthalphy valuses at a specific condition. When you are working on a heat balance, all you are concerned with the the differences in enthalphy anyway.
    Ken
    Jan 2006
    romania
    59
    Thank you US Iceman.
    Best regards, Marian
    JORGE's Avatar
    JORGE Guest
    Hi! Thank You Us Iceman
    Jorge
    lucky_jenie's Avatar
    lucky_jenie Guest
    Thanks, im need it to do my report.
    Greener's Avatar
    Greener Guest
    Quote Originally Posted by TXiceman View Post
    Ken
    Hello,
    I also have found that different manufacturers and textbooks use different reference temperatures for their p/h diagrams.
    Can anybody tell me why this is?
    Coolpack seems to match the enthalpies to the relevant saturation temperature / pressure. Why isn't this the case for all other p/h diagrams?
    Thank you.
