21-10-2012, 10:49 AM #1
Toshiba RAS 13UKV Service Manual?
Hi, I'm cleaning up a 7 year old Toshiba high wall split heat pump ready to fit in one of our rooms and would like to download the service manual for interest. The unit seems to run fine but it's always interesting to have the technical information as well. I tried downloading it from here:
http://www.toshiba-aircon.co.uk/technical/Residential/RAS%20Inverter/Service/RAS-13&16UKV-E3%20SVM-04013.pdf but the PDF is no longer available.
If anyone has a file or a link that works that would be great thank you. I've searched the various manual links that come up in the 8 pages of search results but they are either dead or for later models only. Thank you, Tony.
21-10-2012, 10:24 PM #2
Re: Toshiba RAS 13UKV Service Manual?
Found an owners manual, helps with the remote ????
http://www.toshiba-aircon.com.au/Man...UAV-UKV-E2.pdf
Found a 2003 service manual might be suitable, came from a French site.
https://dl.dropbox.com/u/19953503/Toshiba-ras13ukv.pdf
21-10-2012, 10:40 PM #3
Brilliant, many thanks for your help Brian!
22-10-2012, 10:52 AM #4
And a hearty thanks to Matt at Heronhill for finding the Service Manual for the E3 model! I had not clicked that there was an E, E2 and E3 series until Matt asked. So have uploaded it to my Dropbox here.
Thanks again from the other side of the world!!
