Results 1 to 1 of 1
Thread: Question about Evap Coil?
15-10-2012, 01:33 AM #1
Hi Folks,
Sorry if this is in the wrong section. I do not work in the field of refrigeration, but have a technical question I would really appreciate some help with!
I have an evaporator coil that I would like to use on a used walk in cooler box that I purchased. I am wondering if this coil would be well sized/suited to the application?
Model: Keeprite R775A (low velocity, 7900 BTU capacity, I believe.)
Application: 10' x 10' Cooler, fresh produce.
Ambient Temp: Climate controlled indoor setup
Any help would be great!
