    Dec 2005
    South East England
    56
    155
    Earth tapped transformers
    Had a look at a Whirlpool Ice M/C today, the type that makes a block of ice that then slides onto a hot-wire cutting grid. The grid is powered at 20 volts from a step-down transformer. Now I think I've got a reasonable understanding of things electrical & even electronic -but what does the earth tapping part of the transformer do There was a live @ 230vac going in & the (I guess) 20vac live & neutral going to the cutting grid, but no neutral supply on the 230v side, just a cable going to earth from the windings
    Noah had to leave the dinosaurs behind as they would've sunk the boat.
    Oct 2001
    Nottingham UK
    5,668
    Re: Earth tapped transformers
    This sounds like an autotransformer where the secondary winding is part of the primary winding so as to give increased current capabilities to the lower voltage side. Have a look here http://ourworld.compuserve.com/homep...h/autoxfmr.htm or do a search for autotransformers
    Jan 2003
    Venezuela
    58
    22
    Quote Originally Posted by phil68
    As Frank says it is most likely an autotransformer. They are cheap, but not particular safe, as there are no isolation between primary and secondary side.
    A standard autotransformer (step down) is shown here.
    A________________C
    {________D
    B_______{
    If you have 130V between A-B, 20V between C-D and B is live and A neutral, then all is good and it will not kill you if you
    touch C or D.
    If, on the other hand, you connect the live to A and neutral to B, then C also will be live, and it is not safe to touch C or D. This
    possibility you can of course eliminated if you connect B to live and A to earth. Normally this would cause no trouble, but I am not sure if it is permitted to use earth as neutral in this way.
    Also, if the connection to A is open (blown fuse (fuses are not allowed here)) then again you have an unsafe situation.
    Saludos cordiales,
    Jan
    Jan 2003
    Venezuela
    58
    22
    Sorry, my drawing went to hell.
    I hope all know how my transformer was supposed to look.
    Jan
    Attached Files Attached Files
    Sep 2005
    Atlanta Georgia USA
    69
    80
    phil68
    In the US many codes require the secondary of transformers be grounded.
    The primary and secondary are individual curcuits. You have to check phase to phase to get accurate readings.
    Steve Wright CM
    Mar 2004
    624
    21
    Here,s some helpful info on whirlpool ice machines.
    www.truetex.com/icemachine.htm
    Regards Bernard
    Oct 2001
    Nottingham UK
    5,668
    Good link Bernard but his methods for re-charging the unit -
  1. Earth faults
    By reggie in forum Technical Speculations
    Last Post: 28-01-2006, 06:22 PM
  2. google earth.
    By Temprite in forum Computers & the Internet
    Last Post: 18-08-2005, 10:32 AM
  3. Earth continuity
    By bernard in forum Electrical
    Last Post: 04-04-2005, 06:35 PM
  4. 21st centry refrigeration system
    By dan wong in forum Technical Speculations
    Last Post: 20-04-2002, 12:30 AM
